Televison & Video Logo
Posted on Nov 21, 2009
My friend sat the TV on the bed when we were moving it and it fell on the carpeted floor but it won't turn on now...do we need to trash it or is it fixable? model # - DU1901
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
901
Points
8
Scrap it sounds like it busted a circuit board you will pay more to fix it then you will for a new tv
tip
Furniture Cleaning/Polishing/Dusting Atlanta GA 678-954-7553 House Cleaning...
HOUSE CLEANING SERVICES ATLANTA GA 678-954-7553 OFFICE CLEANING - ATLANTA,CANDLER PARK,EDGEWOOD,KIRKWOOD
24/7 Cleaning Services decatur GA.678-954-7553 House Cleaning Services
Professional Residential,Commercial and Industrial Cleaning Services
YOU MISSED A SPOT http://www.cleaning-services-atlanta.com
HOME OUR COMPANY OUR SERVICES JOIN THE TEAM REQUEST SERVICES SERVICE AREAS CONTACT US
CSA Foundation-helping premature babies with critical illnesses : 24 7 Professional Cleaning Services Serving All Areas of Metro decatur Georgia. Cleaning Services decatur utilizes the most effective antimicrobial, antiviral, disinfectant/decontamination products on the market.
Residential Services | Commercial Services | Move Out Cleaning | Window Cleaning | Tile Grout Cleaning | Hardwood Floors Polishing
Carpet Vacuum and/or Deep Cleaned
Floors Cleaned and/or Waxed/Refinished
Keyboard and Desk Dusting
Bathrooms Cleaned/Restocked
Offices Cleaned
Exam Rooms Cleaned/Restocked
Waiting Rooms Cleaned
Employee Lounges Cleaned/Restocked
Trash Disposal
Windows Cleaning
Emergency On-Call Service
Trash Disposal
Windows Cleaning
Basement/Attic Cleaning
Lawn Care
Pressure Washing
Rental Properties Move-in/Move-out Cleaning & Painting
Property Abandonment Cleaning
Military/Veteran
Senior Citizen
Disability
Student
Frequent Customer
20% OFF 1 MONTH (+) SERVICE AGREEMENTS CLEANING SERVICE decatur - "LET US DO THE DIRTY WORK FOR YOU"
TESTIMONIALS
DISCOUNTs
COUPONS
CSA FOUNDATION
FAQ's
Cleaning Service decatur provides affordable office cleaning services. Our cleaning maids are honest and professional. Our services include: business/commercial cleaning and residential cleaning; offering windows cleaning, carpet cleaning, tile cleaning, grout cleaning, refinishing hardwood floor, wax floors, garbage and waste management, furniture cleaning, polishing and dusting, and much more. We offer service to the metro decatur population. We accommodate medical offices, business offices, nursing homes, day cares, schools, hotels/motels, etc.; Special Events including: Wedding venues, Parties, Concerts, After Parties etc.
on Aug 02, 2010 • Home
Fuse
How high did it fall from? Any lights come on when it is plugged in?
1helpful
Tv fell off the stand onto a carpet floor now wont turn on
Possible that the fall has damaged the mother board and so there can be CRACK ON THE MOTHER BOARD. So you need to remove power cord and check using a good inspection lamp on the board for broken circuit board. Use a good soldering iron with wire strips to join - take care not to short circuits as each line must be tested for short and continuity.
2helpful
2answers
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
I have 2 rings problem
You've already deduced that 2 red rings means overheating. Here is a list of what to do to make sure there is no external reason for the overheat. It's all pretty obvious stuff but it sometimes helps to go through it methodically (My friend had his sat on the carpet - he got 2 red rings after about 3 hours)
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
  • As it happens my X360 has been sat on top of my Amp for 2 years although I rarely have it switched on :P
    Won't stay on.
    you have caused some internal damage you will have to goto a reapir shop.
    My Tv doesn't power on!
    hello the glass fuse inside the tv might have come out or worse the circuit board might have broken
    shaun
    3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
    hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
    Top Durabrand Televison & Video Experts
    matt martin
    matt martin
    ZJ Limited
    ZJ Limited
    Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
