Question about Bose 3·2·1 II System
No audio with CD/DVD but works fine with aux and FM
I bought BOSE 3.2.1 GS Series II DVD Home Entertainment System
It has some problem with the DVD player
Its working fine for FM and Auxilary audio and vedio, but no audio if i play CD or DVD. I tried with BOSE 3.2.1 Setup DVD itself, vedio is OK but no audio.
I assume that connections are fine as it is working fine with FM and AXU inputs from my iPod.
I tried changing system settings for audio but no luck.
  • BhaskarReddy Jan 18, 2008
    I too doubt either DAC gone bad or CODEC itself, because even Audio CDs wont play. As I have moved out of USA, I could not able to get much help from BOSE. I ordered it online from bose.com
    Thanks for your help.
  • 16 Answers
Check the cable between the media centre and bass module for signs of damage (if its buried in the wall / under the floor and you can't check it, assume it could be damaged).
however, this sounds like a fault with the Digital Analogue Converter - this coverts the digital audio on a disc to analogue information the amplifer can use to produce sound. Contact your retailer for exchange / repair.....
Posted on Jan 16, 2008
  • Lewis James Jan 18, 2008
    What country are you in now? Presumably it's a 120volt system - what is the mains voltage in the country you are in? If your using a voltage converter, it may not be powerful enough. If so, to even have a hope of working, it needs to be a voltage converter rated at 500watts. The 321 systems draw up to 350watts of power - if the voltage converter isn't powerful enough (i.e. rated less than 385 watts as you need to allow 10% on top), not all functions will work.
    Ideally, have the system converted - most Bose subsidiaries or distributors offer this service.
Connecting a turntable to a Bose 3.2.1. Series II
Bose 321 GS Series II DVD Home Entertainment System is a newly redesigned, sleek media center that includes a DVD/CD player, AM/FM tuner and inputs for three additional sources. The 3 2 1 GS Series II system now has even greater ease of use and setup. The 3 2 1 GS Series II system is for customers who want the benefit of home theater sound but would prefer the simplicity of two visible speakers, a hideaway Acoustimass module and fewer wires so they don't need to run wires to the back of their room. Media center plays - DVD video (including progressive scan formats), AM/FM, CD, CD-R, CD-RW, digital 5.1, and MP3 files on CD AM/FM radio includes 20 presets, scan and seek Three audio inputs with both analog and digital coaxial jacks, and one optical digital audio input, provide greater setup flexibility Dimensions - media center, 31/6H x 133/4W x 99/10D (8.02 x 34.93 x 25.27 cm); speaker arrays, 21/2H x 51/2W x 41/8D (6.4 x 14.15 x 10.52 cm);module, 141/2H x 83/4W x 191/8D (36.7 x 22.2 x 48.5 cm) Weight in carton - 44 lbs (20 kg) One-year transferable limited warranty
and from the review
Audio-input connectivity is a bit more robust. You can connect three audio sources through analog or digital jacks. The system is compatible with MP3 CDs and can decode Dolby Digital and DTS surround soundtracks from DVDs and external sources.
Bose 3 2 1 GS Series II DVD system review
May 14, 2017 | Bose Audio Players & Recorders
Bose CD player wont turn it on at all
Plug it into another wall socket, try it there. Then turn off all lights in room and plug it in, see if you can see any glow or LED inside it or outside. Then check the fuse in the plug if there is one.
Dec 15, 2013 | Bose 3 2 1 GS Series II DVD Home...
How i sync a ilink box codes to a bose remote control sistem
I have the same problem but my remote is Bose Cinematic and in the list does not appear. Can somebody help.
Sep 21, 2013 | Bose 3 2 1 GS Series II DVD Home...
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
Can someone tell me how the picture is when playing a dvd to a hdry set. I heard it's not very good. Thanks John
Did you mean : playing a normal dvd on a HD tv? ....It will be fine. Check your dvd menu to see if it can upscale. If your using a huge tv you will notice some grain...but hopefully your not sat 2ft away!
Aug 08, 2009 | Bose 3 2 1 GS Series II DVD Home...
Expanding the BOSE 3.2.1 System to other rooms
I don't see any standard RCA Line Level audio outputs on it, do you?
Apr 19, 2009 | Bose 3 2 1 GS Series II DVD Home...
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose 3·2·1 II System Logo
129 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
