Samsung Blackjack SGH-I607 Smartphone
Problem for Samsung Blackjack SGH-I607 Smartphone
Blackjack won't turn on
By kitojhd on Jan 12, 2008
battery is charged but the blackjack won't turn on
Same Problem
May 03, 2009
-   my phone turns on.. and goes to main screen..
but i cant make any phone calls or text at all because it says my phone is off...? hoiw do i fix that?-   a_n_perez_3
Mar 21, 2009
-   blackjack 1 that won't pickup signal regardless of what we try. changed sim, hard reset, etc-   Guest
Mar 07, 2009
-   thats some ********. my **** died and i cant get it to turn back on. not pysched -   Guest
Mar 07, 2009
-   My Blackjack was turned on the whole day, but when I checked it at the end of the day it was off.  I tried to turn it on, but it didn't work.  I tried charging the battery up, that didn't work either.-   Guest
Feb 18, 2009
-   i brought it to the store, they took my phone in the back and then said it had 'water damage.'
my insurance paid for it, thank god.
then about a month later, my sim card stopped working out of nowhere :[
they gave me a new one for free. -   asdfhjkl
Best Solution
posted on Sep 11, 2008
Helpful)
siddharthb03
Rank: Apprentice
Rating: 83%, 9 votes
take out your microSD card it solved the problem for me.
Was this helpful?
Yes
No
Solution #2
posted on Oct 22, 2008
Somewhat Helpful)
lockoutsoflo
Rank: Guide
Rating: 83%, 7 votes
hold the up key and power on format, then you need to find someone with the same phone start to update the phone with usb cable and when it ask you to restart your phone plug in your broke phone and it will upload everything, not a pro so do research on this!
Was this helpful?
Yes
No
Solution #3
posted on Feb 06, 2009
Helpful)
yellowhouse
Rank: Apprentice
Rating: 83%, 6 votes
THe BlackJack phone will only charge while its turned on! If you allow it to go totally dead you cannot recharge it. You will have to get a new battery.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Feb 09, 2009
Somewhat Helpful)
richardhod
Rank: Apprentice
Rating: 75%, 2 votes
For my dodgy button I used a tiny screwdriver to lever between the power button and the casing join in the middle of the top edge. magic turn on., Now to back up. and get a new machine from Samsung.
Was this helpful?
Yes
No
Popular Solutions for Samsung Blackjack SGH-I607
Questions and Unsolved Problems for Samsung Blackjack SGH-I607
Do you recommend Samsung Blackjack SGH-I607 Smartphone?
Answer
Answer
i want to gprs settings for bsnl for samsung gt-b7320
Answer
and if it does it onlythe phone wont turn on, and if it does it only starts to flash.
Answer
I found this phone and is lock it uses a sim card but when your power on the phone it says phone... (More)
Answer
can i connect samsung m200 for internet on laptop?
30 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 04, 2009
Everything works but my phone wont turn on
Comment by asdfhjkl, posted on Dec 07, 2008
my phone lost a signal and wasn't getting one back, so i was going to turn it off and then back on. i have done this several times before.
but once i turned it off it was like the power button stopped working..
i tried taking out the battery and sim card and then putting them back in, and i tried using a different battery. nothing has worked. the screen just stays black.
Comment by Guest, posted on Dec 05, 2008
my fone is On but the it says the fone off
Comment by kendj0709, posted on Oct 21, 2008
blackjack powers up but will not turn on
Comment by zeus1997, posted on Oct 15, 2008
I went to unlock the phone and all of a sudden it went black. It was fully charged. I tried recharging, taking the chip out and back in, wall charger, usb charger. Nothing worked and sounds like it happens alot and ATT will probably said it got damaged or was messed with until maybe they get a couple of thousand complaints of the same results.
Comment by Guest, posted on Oct 13, 2008
same, charged, wont turn on
Comment by ricksuns, posted on Sep 30, 2008
after upgrade to WM6 phone will not turn on and unit will not reset
Comment by tkbkjames, posted on Sep 28, 2008
Can't get my phone to turn on, please help.
Comment by Guest, posted on Sep 24, 2008
My BlackJack just stays on the Windows Mobile screen forever and doesn't go anywhere after that :(
Comment by Guest, posted on Aug 28, 2008
Same as the others. Phone just crapped out and won't recharge. I take the battery out and when I put it back in it makes it to the 3G logo and then goes black.
Comment by sk8tr007, posted on Aug 12, 2008
phone wont turn on im pissed
Comment by Guest, posted on Aug 09, 2008
It's worked perfect for 14 months, then Wednesday night it works, i set it on my desk when I woke up in the morning it wasn't working. I took out the battery and replaced it but it still wouldn't work. I had a new battery I charged it up placed it in and still nothing, it won't turn on! HELP!
Comment by xobreaathe, posted on Jul 22, 2008
my phone won't completely turn on it just starts up and stays at the start up screen w/ the cingular bars. The other day i had a problem charging it. but now my phone wont turn on at all any help?!
Comment by BigDogatPlay, posted on Jul 01, 2008
The battery on my Blackjack drained. Phone will not turn on now, plugged in to charger or computer. Took battery out and put back in, still nothing.
Comment by Guest, posted on Jun 28, 2008
Blackjack ll will turn off and not turn on unless I remove battery and then put it back in. Help
Comment by jadehannah_, posted on Jun 27, 2008
The screen on my BlackJack went white a couple days ago and now it won't turn on. I've changed the battery took out my sim card, and done everything I could possibly think of. HELP!
Comment by lindsislovex, posted on Jun 27, 2008
battery is fully charged, but it wont turn on
Comment by Guest, posted on Jun 16, 2008
battery full screen says "power off" did both hard resets managed to loss all my data but still no power on.
Comment by Guest, posted on Jun 07, 2008
I can't get my blackjack II to turn on. The screen went blank and I haven't been able to turn it on since. I've tried plugging it in, taking out the battery, hard resetting it...nothing!
Comment by Guest, posted on Jun 03, 2008
my black jack said main battery low then i plugged it in to the computer charger to charge not charging at all.
Comment by coolnajmi, posted on Jun 01, 2008
Phone will will not turn on even after hard reset Phone says phone off
Comment by Guest, posted on May 26, 2008
i flew into bangkok - and bang - my blackjack 2 would not power on - i'm ready to throw it away, and get a cheap phone over here.
Comment by ladyalchimia, posted on Apr 30, 2008
I have the exact same problem, and I did take the battery out and reinstall it, but it didn't work.
Comment by patchesnb, posted on Apr 23, 2008
Blackjack SGH-i607 won't power up at all. Swapped battery, left on charger, pulled sim, and still nothing. Was working yesterday, left on and this morning, nothing.
Comment by Guest, posted on Feb 22, 2008
Mine wouldn't turn on so I pulled the battery out and put it back in. Now it turns on. This is a reset feature for wince.
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in Windham, ME
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
