Question about Dell Axim X3 Pocket PC
Can it be sync with OFFICE 2003 ?
Am using it to sync with Office 2000 at the moment. I need to install Office 2003 soon. Can Axim X3 work with Office 2003 ?
  • rjyeng Feb 22, 2008
    Thank you very much indeed. It works perfectly alright.
  • Anonymous Jul 14, 2008
    can't sync get an error message. I had a different dell and got another one and I deleted active sync and reinstalled but I have outlook 2003 is that why I am getting the error message. thanks
    Sergeant:
    Champion:
  • 317 Answers
Yes, it works flawlessly with office 2003, but not 2007.
Posted on Feb 21, 2008
I am using windows xp, outlook 2000 and an iphon 3gs It seems i am not able to sync the phone to office 2000? I have tried to sync outlook with windows address book bu this doesnot seem to sync - i can...
Apple currently only supports office 2003 and up syncing to the device. Sorry your out of luck. But the newer versions of office are a welcome upgrade and have many good features if your looking to upgrade
Mar 21, 2011 | Apple iPhone Smartphone
Can't Sync to my PC!!
You see the icon of Axim X5  on my computer???
Oct 31, 2007 | Dell Axim X5 Pocket PC
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Is my Axim X30 compatible with MS Office 2007?
If you save the document in word 97/2000 it should work with the X30 version of word.
Aug 14, 2009 | Dell Axim X3 Pocket PC
Can't sync with Outlook 2000
Outlook 2000 is not compatible with windows vista
Mar 25, 2009 | Toshiba e335 Pocket PC
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Microsoft Office Trial Version and Upgrade
I bought an upgrade version and it doesn't work. What should I do?
First, please confirm you meet the qualifying criteria for an upgrade purchase. To qualify for an upgrade you must have a valid license for one of the following products: Office Standard Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Office 2000-2007 (any program or suite), Office XP (any suite) Office Small Business Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft OfficeXP (any suite) Office Professional Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft Office XP (any suite) Project Professional Microsoft® Office Project Professional 2000-2003; Project Standard 2000-2007 Visio Professional Microsoft® Office Visio® Professional 2000-2003; Microsoft Office Visio Standard 2000-2007 Visio Standard Microsoft® Office Visio® Standard 2000-2003; Microsoft® Office Visio® Professional 2000-2003 Live Groove Microsoft® Office Live Groove® 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Publisher Microsoft® Office Publisher 2000-2003; Microsoft Publisher Deluxe 2000; Microsoft Publisher with Digital Imaging 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Small Business Accounting/Office Accounting Professional Microsoft® Office Small Business Accounting®2006; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite)
Found here:
http://us20.trymicrosoftoffice.com/faq.aspx?culture=en-US
May 28, 2008 | Computers & Internet
Product key
Yes, you should be able to sync with Outlook 2000.
Sep 19, 2005 | Dell Axim X3 Pocket PC
Sync problem
I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sep 15, 2005 | Dell Axim X3 Pocket PC
Sync problem
I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
Dell Axim X3 Pocket PC Logo
54 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
