Question about Dishwashers
Miele dishwasher problem
Our dishwasher is making a harsh noise when it begins running and again early in the cycle. We have heard it during a couple of cycles and it is not related to a loading issue.
  • 1 more comment
  • Anonymous Mar 12, 2008
    our zanussi zsf4123 stopped and threw the main jack.suspected heater element as when power was put back on jack held and could hear washer filling.after ten seconds jack went again. removed heater element and electrician confirmed u/s. new one obtained and fitted. now dishwasher just stands with power to it but wont start any cycles. have i disturbed something else or has a float switch stuck,any ideas please.
  • Richbney Mar 30, 2008
    My Sears Kenmore Elite dishwasher also makes a harsh noise during operation.Does not seem to affect cleaning does not sound good. I took the inside pieces apart to see if anything was lodged somewhere.I found a piece of broken glass below but nothing else. Still making the same noise but it may be a little quieter. Your ideas would be appreciated.
  • ditom2000 Sep 03, 2008
    kenmore elite just started making shrill noiseduring wash cycle but not when draining otherwise seems to work well only about a year old any suggestions ----Tom have done nothing yet but its on the to do list.
Good flow of water
Posted on Jan 12, 2008
I have a Miele dishwasher model G2120SCU. When turned on, all three yellow lights light up and the unit will not begin wash cycle but makes a noise (possibly the drain pump??). Any idea what the three...
Yes, It means call the technician 800-999-1360
Three blinking lights can be anything either- no drainage, no water, no circulation pump, no salt, etc. based on the model. Each control board code is different on each model.
The technician will provide free step by step instructions to clear the fault and advise you how to get the problem fixed.
Dec 27, 2014 | Miele Dishwashers
Brand new LG LDF6920 makes a whistling/high pitch squealing noise even during 1st test run, no dishes no contaminants added. It is during the wash motor cycle once the wash pump gets up to speed *screech*....
I had a brand new Dishwasher do that, it wasn't an LG it was a Frigidaire i think, turned out to be some bits of plastic from the manufacturing process that were in the pump. I had another one that made thumping noises and turned out to be a little piece of the tape, you know all that blue or green tape they hold everything in place with when its new. Did you run it through a few cycles and see if the noise quit? Believe it or not when i called about the one that was squealing their customer service said to run a couple cycles to remove anything that might be in the pump from manufacturing, sure enough midway through the second wash cycle it just went quiet and never made another noise again after two years.
Jan 11, 2018 | LG Dishwashers
Hi, my Miel, Inspira series dishwasher makes a very loud grinding noise for a few seconds and shuts down...
It must be trying to drain out water but the pump mechanism might be rubbing due to faulty bearing. Need full model number before I can give you more details to look for. Is this happening right at the beginning of the wash cycle?
Feb 11, 2011 | Miele Dishwashers
Hi, my Miele G1142SC makes noise at startup
Mine is doing the same thing. I tried running a finish cleaner though a cycle. I did nothing I was about to do the same thing again when it just stopped doing it. What did you end up doing?
Jul 20, 2010 | Miele Dishwashers
Water does not drain
Hi
You can :
Check for hose kinks or food plugging drain hose. Start at the drain port exit
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check timer for not letting the dishwasher pause. ( not all dishwashers )
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
Dishwasher not stopping
If it keeps going around then it is probably the programer timer motor unit. You will need to call Miele.
Jul 09, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Dishwashers Logo
317 people viewed this question
Top Dishwashers Experts
