Question about Dishwashers
SMEG DISHWASHER - SUPPLIER CODE : SA8605XTD
DISHWASHING TABLET DOOR NOT RELEASING THE TABLET TO WASH DISHES
  • barneygumble Feb 15, 2008
    Can anyone help me? My smeg dishwasher wont release the tablet. I have had nothing but problems with this dishwasher. Please help!
    Simon
All questions on dishwashers, you could visit website www.dishwasherworld.biz and find answers in forum.
of course, you could ask questions as well.
Posted on Apr 24, 2012
Hi, I don't usually put the tablet in the door holder. I just place it in the bottom of the washer . I aways am concerned that there will be soap residue. So this way utensils are getting washed as soon a the washer commences .I usually scrape debris off plates and utensils before I put them in the dishwasher. This works well. Hope this works well for you. Teresa
Posted on Apr 19, 2008
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
Smeg DW167.1 error code
I HAVE A SMEG DW167.1 AND IT COMES UP WITH A E9 FAULT, DOES ANYONE KNOW WHAT I CAN DO TO SOLVE THE PROBLEM ,THANKS
Jun 22, 2012 | Smeg Dishwashers
I went to take out my dishes out of the dishwasher this morning and the tablet was sitting at the bottom of the machine half disolved and most of my dishes weren't washed properly. What is the problem?
1. Check that water enters dishwasher.
2. Check that water is heated,tablet door will then open, this allows the propellor to shoot hot water at tablet to dissolve.
Apr 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
SMEG SA 425 x Dishwasher - washing spinners stopped!
Can you hear the wash pump operating during the cycle? Pump could be faulty or blocked, or the pcb could be at fault
Jan 06, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dirty dishes
check manual,your water hardness and salt/detergent quantities can make a big difference,theres usually some switches you can adjust for salt/detergent,if not check for partial blockage in pump etc,may be not enough water comming through.
Nov 02, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Not cleaning properly
You could be using the dishwasher at a higher temperature than the biological agents in the tablets can handle, and so become denatured and can't clean your dishes properly. I have had this problem a little while ago and found that using the "eco" setting (should heat the water to around 30c and has the added bonus of using less water) works well and makes sure that all of the dishes are clean.
It could also be a problem with the release system, where the door the holds the tablet can't release it on time and so the tablet does not dissove. Have a check to see if anything is stopping the door opening and see if there is anything you can do to make it release on time.
Hope this helps,
BurntLime
Jan 05, 2009 | Dishwashers
Timer Knob Smegdishwasher sa 620x
I have this same model Smeg dishwasher. 1 = Soak - pans and dishes awaiting completion of the load. 2 = Strong - Very dirty pans and dishes dirt dried on. 3 = Normal - Normally dirty pans and dishes. 4 = Rinse - Dishes requiring "refreshing". If you would like a full copy of the user manual, send your address to "brockjack@g-node.com.au" and I will photocopy our manual for you.
Oct 06, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
386 people viewed this question
Top Dishwashers Experts
