Question about Bosch Classixx WFO 2466 Front Load Washer
New Bosch Front loader washer Maxx Classic WAE18060AU
Having great difficulty balancing machine. Is walking badly on spin cycle. Any tips for getting the balance correct. I have used a level, a ball, physically rocking......HELP PLEASE.
  • psaib Jan 13, 2009
    I purchased a second hand bosc maxx washing machine and dont have a manual. I need to access a manual please
  • Anonymous Mar 23, 2014
    machine will shut down when there is about 5 minutes left in the spin cycle. F6 and E1 flash.
Remove the 4 transit bolts from the back of the washing machine. These are supposed to be remove during installation. If they are not removed the machine jumps around like crazy on the spin cycle and the machine is almost unusable.
Posted on Jan 04, 2010
  • 1,294 Answers
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Posted on Jan 12, 2008
Machine does wash cycle OK , but makes whirring noise and does not spin to empty machine
Posted on Jun 12, 2010
    New Friend:
Didn't remove the bolts and never thought that was the problem. Thanks for blogs like this I can relax and take care of my baby and laundry in peace,
Posted on Nov 22, 2012
If machine new have transit bolts been removed from rear of drum it amazes me how many of these get left in after delivery machine will go crazy if these left in drum should move backwards and forwards easily when door opened and drum pushes if solid remove bolts.
Posted on Jan 18, 2008
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
May 17, 2012 | Washing Machines
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I wash delicates, which drawer, what soap or detergent, etc., front loader Bosch machine, bought recently, (lost manual).
WAE18060AU im leaving this on this page becuase it is a model number to a maxx classic the look up site is currently down for maintenance ill message you back in about 6 hrs Rick
Jan 15, 2011 | Washing Machines
How do I replace the door seal to a Bosch Front loader washer Maxx Classic WAE18060AU?
To change the seal the easiest way is to take the front of the appliance off. Remove the kick plate at bottom and you will see some screws holding the front panel on remove these Then open door and remove the screws holding the door lock on and unlip the seal by releasing the clamp on the front. The front should now lift off, if it doesnt then pull out the soap drawer and behind that at the bottom of the drawer is a screw holding the front on remove this then push the front panel down then it will lift off You can now take the clamp holding the seal to the tub off. Fit the new seal, fit the clamp to the seal and tub. From here, rebuilding is the reverse of the strip down.
Feb 18, 2010 | Bosch Classixx WFO 2466 Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Bosch Classixx WFO 2466 Front Load Washer Logo
1,738 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
