Question about Akai PT46DL10 46" HDTV-Ready Television
Color is out of whack
I've changed the bulb and the picture is working now, but the problem is that it is really green, i've tried adjusting it and nothing seems to work. Also the lamp light did not go off after changing the bulb. Im about ready to throw this tv to the curb.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Get r done
Posted on Aug 03, 2008
Have red tint in picture
It sounds like the color settings are out of whack, try going to the tv settings and reset them back to default. Then try changing the Red green blue values (RGB) in the color settings, simply lowering the red value might do the trick
Apr 10, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
My picture all of the sudden went bad. You can still watch tv but the top of the picture is a little warped and the colors are all messed. The images are split into a red and green picture that overlaps...
One of the two convergence amplifier modules has gone bad. I suggest replacing both. They cost about $20 each. You may also have to replace a few resistors or a fuse. The labor is actually not all that difficult for an experienced technician. See the solution KyleM_73 provided for more details.
Note: it is possible to adjust convergence using certain commands from your remote control. DON'T TRY IT UNTIL YOU FIX THE FAILED AMPLIFIERS! You won't break anything more, but you will make a lot of extra work to finish the job because the adjustments will only go all out of whack and won't help the picture before it is repaired.
Jan 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is green or yellow
Maybe you should have it professionally aligned with the color values it had at the factory or on display,.
when you first saw it. Sometimes a mere temperature change, as many locales had this week will throw
such an alignment out of whack.
Apr 18, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Blue bulb is lit but no picture
the messed up colors are probably from a burned out convergence chip. not too pricey to fix.
Feb 17, 2009 | Philips 55PW9363 55" Rear Projection...
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Greenish tint to picture
there may be a green tube issue or there could be a screen voltage or screen control adjustment issue. There is a control block with six adjustment screw inside the front panel in front of tv. WARNING high voltage exsit in this set and adjusting these controls really should only be done by a tech,....So be careful
Nov 20, 2008 | RCA D52W19 52" Rear Projection Television
Green and red shadows
try adjusting the color purity knob.one by one,or if it is really bad tube u can extend it by rejuvinating it.
Mar 24, 2007 | Toshiba 43H71 43" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
42 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
