Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
CMOS PRBLEM HaI, MY MACHINE BOARD IS INTELD845 EP. I INSTALLED THE TWO OPERATING SYSTEM 98SE & XP.WHEN I BOOT THE SYSTEM IT SHOWS IN BOOT UP SCRREN CMOS CHCK SUM BAD 005 & CPU CLOCK IS NOT UPDATED PRESS F4 TO SKIP.EVEY TIME I HAVE TO PRESS THE F4 AND SELECTING THE BOOT DEVICE,ALSO CLOCK,WHY IT'S HAPPENS LIKE THIS PLS HELP ME?
  • 689 Answers
Because CMOS-BIOS Battery has drained. You need to change the battery. Battery is CR2032 or similar that can be found any supermarket, Hardware or IT store. After replace to battery Set the System time and restart Issue will resolve.
Good Luck
Battery look like this;
Posted on Jan 12, 2008
Unistall windows xp on a D3315 e-machine
you will need to format your hard drive and load another operating system
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
hope this helps
Jun 20, 2012 | Computers & Internet
How to remove an operating system in a dual boot?
In Windows Xp, you can install two operating systems on the same hard disk of one computer.
Whether you have two copies of Windows Xp, or two different operating systems, then you end up with dual boot machine when you restart your Windows Xp computer.
Dual boot means, the system will give you a choice of two operating system. For example, if you have two Windows Xp copies A ans B, the prompt will offer you to choose A or B to boot from.
Also, dual boot machine can be used to have Windows Xp, and Linux O.S. installed on the same computer.
In the case where you have two windows Xp copies on the same hard disk, you will experience a slow performance in your system.
If you need to delete one Windows Xp copies, and leave only one, here is how you do it:
When you restart your system, and you get a choice of two operating systems, you should choose the one you want to keep installed on your machine.
Once the startup process is done, and your computer is ready to accept tasks to perform certain functions, you click on the "My Computer" icon and locate the hard disks, removable storage devices, and more.
In the hard disk box you should see two drive icons, like "C", "D". If the copy you installed later need to be cancelled, it must reside on the "D" part of the hard disk.
This is because the "C" is where you initial copy of the Windows Xp resides, and it is the one you want to keep installed as the only copy on your computer.
The way you should get rid of the "D" copy is to format the "D" part of the hard disk. just right click it, and choose format. This will delete the Windows Xp copy you don't need.
In summary, you can have two operating systems installed on your windows Xp machine, which will offer a choice of loading one of two operating systems.
The good thing is that you can cancel one, and leave the other, and your computer keeps running.
Feb 01, 2011 | Microsoft Windows XP Professional
After replacing on board lithium cell, computer will not boot up. Goes through BIOS ok but no further, even tried replacing hard disk and booting from removable media drives (after setting BIOS...
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
Jan 11, 2011 | ASUS A7V333 Motherboard
When I try to download xp operating system in my motherbord after copying files when it restart it shows ----"error loading operating system" After that I change my Cd Rom, operating system disc, hard Disc...
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 05, 2010 | Mach Speed PM2MP Motherboard
I have dual boot 98SE/XP-Pro in same disk partition which got virus attack. In order to fix problem (long story), I had to remove and re-install the XP-Pro OS. Unfortunately I deleted the XP system from...
Why would you torture yourself with that old thing?  Yeah, you can create more boot script lines...they should designate the proper root for the second volume and that ought to fix any missing file issues if indeed ICG32.dll and company are where they started....
Jul 22, 2008 | Computers & Internet
Rebuilding emachine - windows 98SE
A C100 error is a registry error. I suggest that U format the drive and reinstall the 98SE. There are programs (bought) available that may fix this problem, but another perferred choice would be to purchase a XP operating system. Boot up on the XP cd and replace the 98SE with the XP. It's better, faster, prettier and more reliable.
May 25, 2008 | E-Machines eMachines Desktop PC
Mother board problem
need more info. ? have you tred other drivs. ?
Jan 07, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Motherboard start problem
i think youreplace the Ram with new one it might soule the prblem
Oct 03, 2006 | Zerus Intel Desktop Board D815EEA...
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
113 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
