Question about Olevia LT32HVE 32 in. LCD Television
Olevia 32" LCD HD TV model 232-S13
I just purchased this Olevia brand 32" LCD HDTV. Only 8 days using it and tonight I turn it on and there is no picture image but just sound. It is not black but it is dark blue. Called Olevia support but there was no help. They took my information and will contact me in the future. Why there isn't no picture just sound? in a brand new TV. Please give me a suggestion.
  • 2 more comments
  • Anonymous Feb 26, 2008
    I have sent back two Olevia 232V LCD HDTV both TV's the HDMI is not working. They will not give me a reason for this.
  • jharrypope Feb 19, 2009
    i had a problem with my olevia right after i bought it and it took almost 2 months to get it repaired. i had to send it back to syntax on my dime and finally fixed it after many threatening calls. now i have a different problem with it. i now have dark areas on the left side of the screen, you can still see the picture but there are dark areas. stay away from olivea. they are nothing but junk
  • tuacay2k Mar 23, 2009
    How do I hook up the Cable Box & the DVD Player to the TV?
  • Anonymous May 17, 2009
    Any solutions?
I have had the same problem with my daughters Olevia...232-S13 out of the blue ti just decides to not turn on...blue light lit where the on/off button located but no sound and no picture....i guess the saying "you get what you pay for" stands clear here.......very upsetting.....
Posted on Oct 18, 2009
Sorry I don't have a solution, but I've had an Olevia TV Model LT 23HVX TV less than one year. Last week, I turned it on, the sensor light is on, but no sound no picture. Unfortuantely, I purchased it from an online auction site, I recently found out the Seller was not an autorized Retailer for the TV. Syntax (the manfacturer) will not honor the warranty. So I've got a piece of junk unless anybody out there can offer a solution. I think Syntax is probably aware of a production problem, but won't admit it.
Posted on May 31, 2008
My tv was working. when i changed the station it dark blue. the channel numbers shows up. is there a solution?
Posted on Apr 13, 2008
2 Suggested Answers
  • 5583 Answers
SOURCE: Olevia 32" HDTV model 232-S13 There is sound
There are a few possibilities. Did the problem occur suddenly or did the image slowly darken or change color (going pink/red) before it got to this point? Do you see anything on the screen if you look very closely. Most likely it is the backlight or backlight inverter.
With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing.
For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Sep 20, 2010
I have an Olevia 32 inch, LCD HD model 232-S13, with a great picture and no sound. Any suggestions?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 16, 2016 | Olevia Televison & Video
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I have an olevia model 232-s13 started to have a fine line throug
you could sell it to me for 100 for parts tony 707 5381732
Mar 09, 2010 | Olevia Televison & Video
I need the codes for a new remote for a Olevia TV
Olevia is an extreme off brand. Try the codes for Polaroid, Syntax ect, all the off brand codes.
Jan 17, 2010 | Televison & Video
Olevia 232-s13 32"
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
May 15, 2008 | Olevia LT32HVE 32 in. LCD Television
Olevia 232 hd tv remote codes
this code dd not work with my remote for the olevia 232v..
maybe i will just buy a new remote for $29.00 and be done with it...; > (
Dec 07, 2007 | Olevia LT32HVM 32 in. LCD Television
32 in Olevia LCD Display Screen Cracked
youre screwed. panels for tvs cost almost as much as the tv, and they are very hard to replace. i suggest you sell the parts out of it.
Oct 21, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT32HVE 32 in. LCD Television Logo
2,888 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
