Question about Cerwin Vega LS-15 Speaker
LS-15 Woofer I just realized that one of me sub woofers is cracked from the middle out it still pounds but would like to enquire on price for a replacement
  • Anonymous May 30, 2008
    i need 2 replacement 15" woofers for dx 9
  • 871 Answers
Realize that we dont live in one place only. prices there might differ from here. but the price of a replacement shouldt be that expensive.
Posted on Jan 14, 2008
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
15 inch in my madza 2003
Did you mean to fix up a sub-woofer within the car rear panel, if so the back panel must be cut off to seat the woofer , sometimes you will need to mount the woofer from the rear hood using a wood plank as the size could be too large to be seated on top.
Jun 29, 2012 | Car Audio & Video
I have a pair of Cerwin Vega LS 15-series home speakers. One of the subs stopped working but still has sound coming out of the voice coil. Do i need to replace the sub?
You need to check the connections on the cross over board and also Ohm out the speaker to see if the voice coil is open. If you cannot get the same woofer, then you should replace them in pair, try http://www.parts-express.com//index.cfm?
Feb 25, 2011 | Cerwin Vega LS-15 Speaker
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
When setting up my receiver the subwoofer is not putting out sound. It is connected and on.
hi,
first of all check ur sub woofer is it working or not. for that pull out its RCA connection from the receiver. power on the sub woofer and touch RCA's middle pin with ur finger. if its working it will produce a hum. if ok, go for the next,
do the following setup in ur av receiver
press menu and select manual setup and press enter
in manual setup select speaker setup and press enter
in the speaker setup select sub woofer and turn it on .
ok
Dec 23, 2010 | Denon AVR-2308CI
I have connected all speakers but not getting anything coming through the subwoofer? I have connected all of my existing Sony suround system speakers 4 corner and one middle and the sub woofer to the...
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
Jun 14, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Sub-Woofer
you must replace the board with new one.
Jun 01, 2008 | Panasonic SC-HT930 System
Cerwin Vega LS-15 Speaker Logo
211 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
