Problem with rca big sreen tv
Rca tv model numd 61w20byx11 serial num e206c10029. the problem is when i turn on the tv the power ligth blink and then shut it self off . Can you tell me what gould it be ? it has high voltage but it shut off.
  • 1 more comment
  • loeth Jan 12, 2008
    when it blink there is no raster tv will turn off right away.i replace the flyback already but still the same problem and friend of mine have the same problem he has the same module and he put hte high voltage pc board and the set working fine and he put he video pc board in the tv is working fine .can you have some idea what it be?
  • loeth Jan 14, 2008
    Did you find out the problem ?.I did what you me to do .Can you please tell me what is going on with this tv? thank you
    I work on this field of electronic for long time .I checked all the connectioins the power supply board . may be i gave you not the right model Try this mod d61w20byx1 and i did solder all the connections but still does not work. My idea is the focus divider or the high voltage may be deffected. What do you think ?
    Genius:
  • 1,665 Answers
First, try a hard reset.
You must unplug the power cord (turning off the set or the strip will not do it) for a couple of hours, then try again.
This will sometimes correct the problem
When it blinks off: Does the raster go dark or just the picture and the raster remain?
If the raster goes dark when it blinks off it means there is a loss of high voltage to the picture tube. High voltage repair is expensive. It may be a failing flyback transformer that is functional inside the horizontal deflection circuits.
If the raster stays on and you just lose video (picture information) then it may be a simple intermittent IC chip in the video board area. It may require a technician to determine which IC and how to replace it or the parts associated with it, but probably not terribly expensive to repair.
Posted on Jan 12, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jan 14, 2008
    I think that Power supply section must be checked first.
    Looking so far for a schematic diagram or repair manual unfortunately did not find yet.
    Are the given data :RCA 61w20byx11 correct?
    If you have some experience on checking for cold solders any cracks, lose connections, condition of switch, power cord, etc do it according safety precautions and try operate again.
    All of the land patterns in the power area must be followed with a soldering iron and touching each suspicious component connection in the power area with the soldering iron. That may resolve the problem or you would have eliminated the possibility of cold solders.
    Kleanthis Mavropoulos Jan 15, 2008
    Your manual can be downloaded here
    http://support.rca.com/doc/Device_Docume...
    chassis must be ITC222. unzip 2 pdf files from the link below
    http://www.eserviceinfo.com/index.php?wh...
    check if these links contain usefull information for your TV.
RCA projection big screen tv will not turn on lite blinks, power to tv is fine.
Check the power supply for electrolytic capacitors with the tops swollen. If you find these (should be either 2 or 4) replace them.
Oct 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Rca big screen
Does the power led blink, when you press power? Please respond to this post and I will try to assist you with the problem. Please respond to this same post when replying
Jul 31, 2008 | RCA D52W19 52" Rear Projection Television
Hitachi T.V.
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Jul 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Tv repair
Does the power indicator blink? If so let me know how many blinks it blinks. Respond to this post so I have a way of keeping your symptoms and model number available for furture responses.
Jun 23, 2008 | RCA D61W20 61" Rear Projection Television
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Fixing a tv
57 inch rca....Sounds like you have a itc222 chasis but cant be sure... what is your model of the set. d52w20 maybe.. or something simular.. blinks green 3 times sound familar... get me that model number and we cant start the troubleshooting process
Mar 03, 2008 | Televison & Video
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
