Question about Microsoft Xbox 360 Console
Xbox 360 A/V Output Teeth
The teeth on the actual Xbox360 console are bent. The yellow teeth where the av output is connected. How do I fix it? How much will it cost?
  • 121 Answers
Owch, maybe microsfot will send you a new one call 1-800-4myxbox otherwise try calling best buy or any other electronic store and see if theres a way to buy one from them.
Posted on Jan 13, 2008
Problem with my LG TV and my XBOX360 , there no picture and sound when i connect my xbox with hd cable.
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
Jun 09, 2012 | Microsoft Xbox 360 Elite Console
Xbox360 e74
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/kb/e74-error-appears-when-you-use-your-xbox-360-console.aspx?kbid=941377
Oct 17, 2010 | Microsoft Xbox 360 Console
Xbox has no video
did you check the cables? are they secured and not loose?
Mar 20, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Xbox360 e74 error code
This problem occurs when the Xbox 360 console experiences a general hardware failure. Contact Xbox live 1-800-4my-xbox
Sep 19, 2009 | Microsoft Xbox 360 Console
No video output, audio output fine
Did this console work fine before, or did you just set it up and it has no video? If the console worked fine before but now it doesn't, you are likely right about the cable NOT being the true cause. However, if you've never seen a picture from your XBox360 then perhaps the cable IS the problem. You mention "all 3 video lines", leading me to believe you are using the HD A/V cable with blue, green, and red connections for video. In order to use this cable, you MUST have an HD capable TV (480p, 720p, 1080i, or 1080p). Try switching the A/V cable switch from HD to TV and using the yellow video plug.
Apr 13, 2008 | Microsoft Xbox 360 Console
Xbox 360 Console
For most xbox360 problems you can send the console in to have it fixed. All you have to do is call the help line at xbox.com and they will send you a box. Then send it back to them. It is totally free.
Jan 13, 2008 | Microsoft Xbox 360 Console
A/v output
Go to walmart or something and get a new AV cable.
Jan 11, 2008 | Microsoft Xbox 360 Console
4 flashing red lights
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
site that explains codes:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 18, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
