Distoration Hi Have a 1988 model that has only just started to give some distortion problems. Unit has been fine till now, any ideas? Peter
  • Graeme Ross
    Graeme Ross May 11, 2010
    What is the amp... more info please
  • 1,512 Answers
I will need a few more details about the amp to give you advice. Happy to help you.
regards
Robotek
Posted on Feb 07, 2008
  • 107 Answers
You need to change some capacitors and transistor or tubes
Posted on Jan 13, 2008
Hi I have a GCB650 blower , I’m mixing it at 40/1 . It’s been giving trouble , it’ll run fine for 10-15 mins then it starts to choke itself on till it cuts off , has anyone any idea what would be causing...
Check compression, it should be at least 90 psi. If less , it needs to be rebuilt , probably cheaper to replace .... try an Echo unit . I will not buy anything else ..
Nov 13, 2017 | Garden
The bike will not start from the electric starter, checked all the connectors and connections and everything is fine been told to check the fuse but cant find them,
Hi Peter:
Try google with question "where is the primary fuse for" ........ and give the make and model of your ride.
Jul 18, 2015 | Power Motorcycles
FT-890AT yaesu transceiver has distorted transmit audio
Hi Ronald,
Could the problem be related by having the mike to close to your mouth? This is the most common cause of over-modulation/ distortion from the transmission end.
If you have the mike 3-6 inches from the mouth and speak in an even non loud tone, that would help sort that out. If this is not the source of the over modulation/distortion, then you may have a transmitter issue, which would require the unit to be serviced by a qualified radio technician or ham radio operator, if you know one willing to look at it for you.
I hope that this has helped you.
Cheers,
Peter
Dec 01, 2012 | Radio Communications
With a full tank of gas starting first thing in the morning cold.. will run fine till about 15 to 20 miles then it starts cutting out as if it is out of gas.. untill it dies and wont start.. have changed...
Before you go any further wait till it stops again then check for a spark and if a spark then fuel ,then i might have a better idea ,keep reply on E mail and feel free to ask again anytime allowing for time zone difference
Sep 07, 2011 | 1988 Dodge B350
Center channel has distoration, Ive switched cables and still distortes?
try to change the center speaker.
if the distortion happens when you rotates the volume control . clean the volume control using isopropile alchohal or any head cleaning solution.,
Jan 09, 2010 | Onkyo TX-SR705 Receiver
1988 Ford Taurus hard start problem
Change the coolant sensor located close to the thermostat housing. This is easy but do not over tighten it. You will have the same problem if you do. Tighten till it does not leak only.Good luck!
Nov 25, 2009 | 1988 Ford Taurus
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
56 people viewed this question
 Grubhead
Grubhead
