Question about Microsoft Windows XP Home Edition
Motorola wireless adapter, Blue Screen Of Death
Now that I have the WPCI810GP 802.11g/b (51803000100) Wireless Adapter installed, after I start up the computer, between 0-10 minutes the Blue Screen of Death (Hardware Malfunction - Call your hardware vender for support - The system has halted) appears, throwing away anything that I was working on and shutting my computer (XP) down.
I tried reinstalling and switching the adapter to a different port.
How can I prevent this, or should I just go buy a brand-new adapter?
  • patrick freebern
    patrick freebern Jan 12, 2008
    Unfortunately I don't have the CD, I got the card from a garage sale. However, I am now getting more like a half hour before the BSOD appears.
    Problem Solver:
  • 8 Answers
1. Uninstall the drivers for the card.
1.5 Turn pc off.
2. Unplug the card.
2.5 Turn on pc. Make sure the pc does not detect the wireless adaptor.
3. Turn pc off again.
3.5 install adapter then turn pc back on.
4. When windows tells you it has found new hardware, click the option to specify your own location for the dirver, then point to the cd that came with the card.
If all this still does not fix it, the you know its the adapter and to take it back.
This same solution works for any new card added to a computer. I have seen this same problem with the old scuzzy cards at work.
Posted on Jan 12, 2008
6ya staff
SOURCE:
BSD (Blue Screen of Death) in the end of installation of NETGEAR N150 Wireless USB Adapter (WNA1100) on Fujitsu Lifebook E2010 with WinXP-SP3. Installation apparently is OK, but all subsequent restart
Go HERE is the latest firmware and keep the router on to the setup page.Open the USB device manage and select updater.Or go to my computer, right click, select manage.This will open the device manager and then right click the USB adapter under network adapters and select update driver.Then select the last option from the menu and remember where is the file of the firmware so you can point the wizard to the file.
Nov 02, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Does this unit plug into back desktop pc
No you can't. But you can connect inside the suitable slot. Only the antenna will be outside.
Jan 17, 2011 | Motorola WPCI810GP 802.11g/b (51803000100)...
TEW-424UB Driver installation for XP
jillibra
To better sew what is going on I need to see the info from your BSOD. The link below will help you get the info I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
Apr 02, 2010 | Trendware TEW-424UB (0710931502572)...
Where can I get a driver for a Motorola 802.11g wireless PCI adapter?
Just log-in to Motorola.com and find there your driver software,, try to look for the correct name and specification of your device for you to download it.
Jan 07, 2010 | Motorola WPCI810GP 802.11g/b (51803000100)...
Since I did a clean install of my OS can not
jeffrundall
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
Thanks
Issken
Dec 26, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Is ithe Motorola WPC1810G compatible with the HP Pavilion F1703
Yes its compatible with it so you should be able to use it on that computer as a wireless network adapter, just make sure you install all the needed software for it......
Dec 02, 2009 | Motorola WPCI810GP 802.11g/b (51803000100)...
Shows connected to interenet wtih 54 mbps but no IE
one thing you may need to do is go in the Internet Options Folder then click on connections tab on the top.. then click on lan settings at the bottom..the put a check mark in the automaticly detect proxy settings.. make sure no other boxes are checked.. close the browser and re-open it.. and so long as you have a connection to your router it should work.. if not post what version of windows you are using and the wireless settings..everything on the page when you run ipconfig post..
Jan 11, 2009 | Motorola WPCI810GP 802.11g/b (51803000100)...
Wireless PCI Adapter WPCI810GP
Hi, In your Device Manager, uninstall all instances of the wifi card, shutdown. Physically remove the PCI wifi cards from the motherboard. Reboot in Safe Mode. Verify that no wifi card is installed in the Device Manager. Power down, reinstall the Wifi Card, reboot, Windows should auto detect and auto install. You may need the original CD installer of the card, if not available, you need to download the drivers before uninstalling the card. As a precaution, use the features of System Restore. Hope this give you an idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 23, 2007 | Motorola WPCI810GP 802.11g/b (51803000100)...
Microsoft Windows XP Home Edition Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
