SOURCE: PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
SOURCE: ps3 turns itself off with flashing red light
Hi My name is Juan and I have one solution for you for now don't do anything even if it stay on for few minutes or you could loose all of your data in your hard drive you have heard about the xbox360 red ring of dead well this is exactly what is happening to your ps3 for now is dead but it can be fix by reflow the VGA chip it is very important to do this with an equipment that is controlled by computer and I do this type of work I am an ebay trusted power seller so don't worry let me know if you want to send your motherboard in to fix it or buy another motherboard I do sell motherboards also
[email protected]
SOURCE: my ps3 turns itself off after a few seconds flashing red light
U SHOLD GO ON SETTINGS AND CHEACK THE TIME BECAUSE U MIGHT OF PUT SLEEPER ON?
SOURCE: PS3 turns off after a few minutes of play
sounds like it over heat....try to take a fan and clean it you need to cool it down a bit for it to work wait a day or so when you put it in a cold breez it should do the trick
SOURCE: Ps3 won't turn on red light flashs on and off
i get same problem, this should work:
turn the main switch off at the back, then hold the eject button then turn on the switch while still holding the eject button. fan should go at max speed then it should die down after 20 secs.
didnt work for me but it should for you.
If the
system turns on but then turns itself off, beeps at you and flashes it's lights
at you then you have over heated the system. The GPU chip has probly pulled
itself away from the board. This will require you to diassemble the PS3...
better u download repair guide....
click here to download repair guide
