Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Blue only misaligned
My convergence let go in two steps, the blue was misaligned first and then a few months later the whole thing let go and I had the whole picture dipping down from the top.  Based on information found here I replaced the STK packs (thanks!).  The picture came back to normal proportion, but the blue is still misaligned.  I entered into the service mode (again found here - thanks) and can adjust the blue up and down, but not right and left.  Red and green are fine.  Did I miss something?  What else can I do?
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 15, 2008
The blue lines on the left lower side of the tv will not converge. The tv has never given me a problem. I woke up one morning and powered it on and noticed the blue is misaligned. I tried converging and...
This problems can happen to the DLP tv any times of it tv life.Tv is 100% have a convergence problems.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture is clear but every thing has a blue shadow effect and all writing has the shadow about 2" under it.
Hi:
Your problem is the blue convergence IC has failed, there are two convergence IC's in this unit and I recommend you have both replaced because if one has failed the other is not far behind, better to do preventive measures now then later. One IC controls the Blue and the other controls the Red and Green convergence.
Jun 03, 2010 | Mitsubishi VS-45609 TV
Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Nov 14, 2008 | Sony KP-65WV600 65" Rear Projection...
Step by step repair guide for blue convergence problem
Good Day;
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vertical movement.
Cause: Replace IK05 (STK392-110) and RK54 (2.2/1W) and converge.
Buy KIT10 at 1-800-458-6053, it contains all upgrades and parts needed for repair. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Hcn653w
Hello pk95953,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Apr 24, 2008 | Samsung HCN653W 65" Rear Projection...
Blue Convergence
Hello All Above,
List price $100
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Blue Non-Convergence
Hi...
These sets quite often lose their memory and can be adjusted with remote control , but , MORE often I have to change the convergence amplifiers. There are two amps with 3 channels each for the up/down left/right for each colour . You did not say if the blue was curved with this displacement , if so AMP or fusible resister . If resister open I will change the amps as a pair. You will need to clean the old heatsink grease off(it will be baked on) and apply a fresh thin coat .
Sorry not for the faint of heart or lack of soldering/desoldering
experienced .
The remote control buttons change their functions when in convergence adjust mode . Let me know If you want the overlay and instructions to adjust.
Later
Hugh Ireland
Jan 08, 2008 | Samsung HCM4216W 42" Rear Projection...
Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Dec 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
