Question about Safa SR-M610F (128 MB) MP3 Player
Battery I'm trying to recharge a battery but it doesnt seem to be working
0 characters
1 Points
My mp3 doesnt turn on it has a new battery in, but has also been sitting idle for a couple months
your device is not taking the ac power bcoz i think your battery is totally discharged for being unusable for long time try to recharge in off mode if it doesnt work you have to buy a new battery
Jun 09, 2011 | Coby MP300 MP3 Player
It doesnt charge!!!!!!!!! its been charging for 3 hours... will not turn on unless its plug in.
It sounds like your rechargeable battery has died. Rechargeable batteries have a limited number of charge/discharge cycles in their lifetime. The battery must be replaced.
Mar 08, 2011 | Jensen MP3 & Digital Media Players
I have a problem with my ipod video i charge it supposedly it will be fully charge after 2 hours but it wasn't i unplug it to it's charger and try to turn on it but it doesnt work. i charge it again and...
It seems so that your battery has run down in retaining the charge to it. Hence even if after several recharges the battery does not retain the charge then it is possible that the battery needs a replacement. You will have to open this piece which is tricky and find a replacement for the same type within. There could also be a possiblity until you open if there is any break in from the battery connection, the reason that it does not work at all with the battery. So check this out. Good day
Jul 13, 2010 | Apple iPod nano
It won't turn on
If you can turn your Player while being plugged into your computer then the issue is your rechargeable battery (otherwise it may be electonically dead).
All MP3 player with inbuilt rechargeable battery do eventually need to have the battery replaced, at a often un-economical cost, after some 18 months or 500 charge cycles.
Dec 24, 2009 | Disney Mix Max Plus DS19025 Digital Media...
IPod nano wont recharge
I would suspect that the battery is no longer good, these must be replaced by Apple contact their websit for instructions on how to do this.
Mar 23, 2009 | Apple iPod nano
Had the same problem with mine. Strip your ipod and you'll find that the left hand end of the battery has been rubbing against the mounting screw for the hold button and the positive track is exposed causing it to short out the battery. Placing a piece of plastic between the battery and the mounting screw sorts out the problem. My ipod charged and the battery still works fine. It seems to be a common problem with this model. If you want more details email me at
Sep 16, 2008 | Apple iPod classic MP3 Player
Doesnt work... at all
The battery on these units dies after so many recharges. You most likely need to replace the battery. It's not difficult and you can usually find replacement batteries on E-Bay for around $20.
Sep 27, 2006 | Olympus m:robe MR-500i MP3 Player
Safa SR-M610F (128 MB) MP3 Player Logo
16 people viewed this question
Top Safa MP3 & Digital Media Players Experts
Are you a Safa MP3 and Digital Media Player Expert? Answer questions, earn points and help others
