Question about Lexmark X5150 All-In-One InkJet Printer
Printer malfunction I HAVE A LEXMARK X5150 PRINTER / SCANNER. PROBLEM, IF I HAVE A E-MAIL MESSAGE THAT I WANT TO PRINT OUT AND KEEP, IT WILL PRINT EVERYTHING ON THE PAGE BUT THE MESSAGE ITSELF. WHERE THE MESSAGE SHOULD BE, IT JUST LEAVES A BLANK SPOT. IT DOES NOT SHOW ANY ERRORS.
    Scholar:
  • 161 Answers
You know another problem might be that the email was printed with a black background and white letters.
I would copy the whole text portion of the email into a WORD DOCUMENT. Try not to carry over any pictures or anything on the sides of your screen, just the text. Then, if the text was in white, you will still see nothing in your word document, but now use select all (which will highlight all the text in the word document and then change the font color. Hopefully you can then print the email out. YOu might be missing the from-to information, which I believe you should be able to copy. Else just forward the email to yourself and edit it as you need.
Posted on Feb 11, 2013
    Scholar:
  • 64 Answers
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Posted on Jan 13, 2008
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
New computer won't print on old Lexmark 5150 printer
You can download the latest driver from lexmark.com .
May 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmar X5150 Printer whit Hardware error 0502, can you Help Me?
http://search.lexmark.com/printer/US/en/17K0000
Download and install updated drivers from this link. If you need a walk through e-mail me your number and I will help you if you rate this fixya. Geokohler@gmail.com
George
Jul 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Nothing working!
maybe...you might want to get fresh drivers, from www.lexmark.com and re install. might work.
Jun 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
Error code 50c
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  12. If you receive the error message again, replace both cartridges.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 scanner locked
Unlock Scanner message
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cartridge stall
I have a lexmark x5150 printer, scanner, copier, and fax machine. I keep getting the message: hardware error 0502. The cartridges are stalled on the left side and the printer won't do anything. Can someone help me??
Feb 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
