Question about HP LaserJet 1200 Printer
Hp laserjet makes a continuous screeching noise when plugged in and will not print.
Hp laserjet 1200 series printer will not print and makes a continuous screeching noise when plugged in.
  • 3 more comments
  • doug050280 Jan 12, 2008
    Thank you for your response ... but removing the cartridge does not help.  It still screeches!
  • fitness36 Mar 18, 2008
    I also had the same problem so I opened the right panel of printer and in the process of it all I removed the two gears that has a spring attached somewhere and now I can't get it back together correctly. As the printer goes through the process of picking up the paper the gears can make it through a full rotation and then the solenoid gets stuck and the gears do not rotate.
  • Anonymous Apr 04, 2008
    I have an identical situation. I have isolated the source of the loud screech to the (laser scanner assembly) p/n RGO-1041. The unit is located underneath the top cover, where the printed paper rests after it is ejected. I had to remove the right and left side covers, then remove the three screws holding down the top cover. There are two screws up front and one to the rear, it then lifts straight up. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
  • hempsteadjb
    hempsteadjb Jan 24, 2013
    where can you purchase the replacement parts?
  • hempsteadjb
    where can you purchase the replacement part?
  • 4 Answers
I have an identical situation. I have isolated the source of the loud screech to the (laser scanner assembly) p/n RGO-1041. The unit is located underneath the top cover, where the printed paper rests after it is ejected. I had to remove the right and left side covers, then remove the three screws holding down the top cover. There are two screws up front and one to the rear, it then lifts straight up. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps. Sorry, I accidentally posted this in problem section.
Posted on Apr 04, 2008
  • 233 Answers
Remove cartridge, does it do it?
Posted on Jan 12, 2008
Just one more note ... the problem started when my wife hooked up the printer usb cord to the wrong port on the back of the computer.  There is a total of four usb ports and one of them is labeled "printer".  She mistakenly plugged the cord into the wrong port.  We were wondering if this would cause damage to the circuitry?
Thank you again for your previous response.
My hp laserjet 1200 series printer will not stop intermittantly printing single pages of a multi page document holtbldr@bellsouth.net
Turn off computer,turn off printer disconnect comm cable for 5 min,reconnect reboot should stop intermitted printing
Jan 18, 2011 | HP LaserJet 1200 Printer
Hp laserjet 1200
If you want the printer driver for your HP printer then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 09, 2010 | Office Equipment & Supplies
HP laserjet 1200 series printer makes a groaning whining noise when it starts up to print; noise continues until it stops.
Sorry, it's old, cranky, and worn out. Live with it, or buy a new one, it's not cost effective to fix it.
Oct 14, 2009 | HP LaserJet 1200 Printer
Hp laserjet 1200 series printer with high pitch nose when in printing process. During this loud noise, the roller turns but the paper is not picked up therefore printing does not occur.
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
Aug 24, 2009 | HP LaserJet 1200 Printer
My HP Laserjet 1200 is screeching constantly
Probably the laser-mirror motor. It will screech until the load gives a error and the printer shows error/ is dead.
However, the motor can be lubed. Remove sides, remove screws found, remove top cover. Remove and open the black box containing laser. Remove motor board and lube the motor, dont get the mirror dirty. Asseble. Total time 15min...
Jun 16, 2009 | HP LaserJet 1200 Printer
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
HP LaserJet 1200 Printer Logo
1,690 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
