Question about Fisher and Paykel GWL11 Top Load Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Hi folks,
Having probs with the above model. It fills OK, but won't advance stages and starts beeping, and has now started reverting to warm water selection instead of cold. Any ideas please.
  • tdak Aug 04, 2008
    Starts off fine but won't progress past 1st green light. When it gets to this light the hot water and cold water light will both come on and start blinking.It will just sit there at that point making a little ringing type sound.
  • Anonymous Mar 29, 2014
    will not spin after fill up
Having the same problem. Any ideas at all? It's really frustrating.
Problem with Fisher & Paykel MW511 toploader washi - noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
Mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Posted on Jul 31, 2008
    Scholar:
  • 196 Answers
Sounds like a possible main control card issue. If this machine is under warranty please call your dealer as these boards can be expensive.
Posted on Jan 12, 2008
SOURCE:
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
The washing machine starts ok and fills with water. However, it quickly begins to intermittently cut in and out whilst filling with water. It does this for a while before stopping completely. I've tried...
you did not mention the type of machine but for top loader the most probable cause of your issue is the door /lid switch that is in need of adjustment as most top loaders will fill with the lid open but cycle cant start or continue when the wash thinks the door is open this is a safety feature
Aug 14, 2010 | Washing Machines
Dishwasher will not advance beyond water fill stage
when it fills and water stops /the motor will start up in a min.or so. you should be able to hear the motor & water or just a hum then the motor will click and quit .. the seak kit came with a tool to center the pump housing properly / if this was done it should work. unplug motor and run thru cycle if it finishes cycle timer ok and pump is still problem . the motor may have been damaged from the first problem and water got in top brg. ck motor see if it will turn ...mm
Nov 22, 2009 | Dishwashers
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No movement, then loud beeping alert
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Oct 17, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
3,277 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
