DTV2784 TELEVISION I AM A TV REPAIR CENTER FOR MAJOR BRANDS FOR 20+ YRS. IN NEED OF A SCHEMATIC FOR THIS TELEVISION. AM DEALING WITH A VERTICAL DEFLECTION PROB. NORMALLY A SIMPLE REPAIR, BUT THIS ONE ELUIDES ME (SP?). I AM LANIER. PLEASE CONTACT. THANKS SO MUCH.
  • ran2mann Apr 09, 2009
    MY DTV2784 SHOWS HALF THE PICTURE AND SHOW A HINT OF RED ON THE RIGHT CENTER OF THE SCREEN AND PICTURE SHAKES CONSTANTLY. I USE TO PLAY MY PLAYSTATION2 GAMES ON IT. AND THIS IS MY 2ND TV DOING THE SAME THING. COULD IT BE THE GAME COMPONENT DOING IT TO MY TV'S?
    Scholar:
  • 170 Answers
DTV2784
Vertical Foldover/No vertical deflection
D402 (1N4002) leaky
Posted on Feb 26, 2008
  • Scott Henderson
    Scott Henderson Feb 27, 2008
    I checked voltage goin to vertical and it was ok.
    Replaced D402 and it fixed the problem.
    Randy's TV Marion,IN
6ya staff
SOURCE:
Emerson EWF2004 has a horizontal line in the middle of screen some color can be seen the rest is black. I disconnected cable, unplugged tv line remains how can I fix it?
This sounds like an analog TV. If so, the vertical oscillator or vertical drive output needs to be fixed. You will need a schematic to do the job.
Feb 25, 2015 | Emerson EWF2004 20" TV
I HAVE A LC401EM2F EMERSON TV 2 YRS OLD. WHEN I TURN ON THE TV I INITIALLY GET GREEN VERTICAL LINES, AFTER IT HAS FOR BEEN ON FOR A FEW MINITUES, THE VERTICAL LINES DISAPPEAR BUT A HORIZONTAL LINE APPEARS...
It sounds like a power surge has damaged the color controller and scan line section of the circuit board. The cost to repair is more then the replacement cost. Next time use a UPS for protection (battery back up for computer and electronics). Regards [email protected]
Dec 18, 2013 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Sansui tv dtv2784
No this TV is not HD ready. However it is digital (ATSC) ready meaning now that most of the analog brodcasts have stopped it will receive the digital broadcasts so you don't need a converter box. Since it can only display 480i resolution it is not HD ready. You would need a TV that can display 720p or better to be considered HD ready.
Jan 04, 2009 | Sansui 27" TV
Schematic Diagram
i need all the names of the components use in a tv schematic or on it board.
Jul 26, 2008 | Panasonic TC-20LA2D 20 in. LCD Television
DS20930 TV
Sanyo makes a fine TV. You have a problem in the vertical circuit causing the line. You should not play the set in that condition because you can dammage the picture tube. Call a few local shops to get an idea of what they charge to fix a vertical problem on a 20" TV. If the cost of repair exceeds about 65% of replacement, toss it. In my opinion the newer sets are lacking in quality compared to older ones. In short , they break more often. If you choose to buy a new TV stay with a known Japanese brand.
Nov 29, 2007 | Sanyo DS20930 20" TV
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Vertical size
make checks on your vertical it could be getting too much voltage replace it along with some cap around that are not filtering the voltage to the ic.because it have cause damage to your vertical change all related components in that circuit also check the related circuits.you can get a schematic for your set at www.samsphotofact.com good luck
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Sep 12, 2006 | SansuiS2001 20" TV
20 inch T.V.
You have a bad vertical output IC, or the sweep power supply that drives the IC is bad. Your going to need the service schematic diagram and the know how to fix solid state electronics.
Sep 01, 2006 | Durabrand DWT1905 TV
Televison & Video Logo
299 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
