Question about Terapin TX-0002 CD-R Burner
Input problem: monitor and thus recording defective, not functioning
Terapin TX0002 not functioning properly.
input problem (front and back):
no monitoring (picture) and so no recording posibility.
play-back and erase working (so, so).
need help to fix, or to contact TeraOptix (which one?)
Thanks PAROVE [prverv@yahoo.com]
  • latu Feb 21, 2008
    can not record
  • myfastrefund Nov 27, 2008
    got a Terapin TX-0002 from ebay, no remote included. No video or audio reception so far, tried to find the code using a universal remote, no luck either, anyone knows how to get a remote or the code?
I do not know if it will help but i do know that if you do have the original remote control, press the M button, make sure your inputs are the ones selected or else there will be now picture. You can hook this up so many ways but chances are your settings are off, press the M button then press the right arrow key (looks like fast forward key) to change current setting, then press the next key to select the next option, after you have all your hook-ups selected press confirm, it takes about 10 seconds then the picture should come up, if not try the digital cable or the s-video
Posted on Feb 27, 2008
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Check engine light po 731
Diagnostic Test Code (DTC) P0731 is a transmission fault code and has a generic description of "GEAR RATIO ERROR IN FIRST GEAR".
The Powertrain Control Module (PCM) monitors the input shaft speed and the output shaft speed of the transmission through the input and output speed sensors. The proper gear ratio will produce a predictable difference between the two sensors. This DTC sets when the expected difference differs greatly from the actual difference between the two speed sensor readings.
This can be caused by several things including:
> Defective input speed sensor
> Defective output speed sensor
> Defective connections or wiring between either speed sensor and the PCM
> Shorted speed sensor circuit
> Open speed sensor circuit
> Slipping clutches inside the transmission
Please note that Transmission Control Module (TCM) replacement WILL NOT correct for this code.
The speed sensor data must be monitored with the proper equipment and the speed sensor circuits must be verified for proper function to determine the actual cause of this fault.
Dec 04, 2011 | 1996 Plymouth Grand Voyager
Dear Sirs/Madam, Please help me the manual of Terapin MCR-TX3300, I need this manual for copy. thanks & regards
Do not know if you still need it. If you still need it, I will send it to you via your email
Jun 23, 2011 | Terapin MCR-TX3300 2-Disc CD Recorder
No signal. Power is on, cable functions well (tested on other computer). nevertheless, the screen does not work (any more) and shows signa " no signal" . What can have gone wrong with my screen...
The fact that you see the "No Signal" message indicates that the display is functioning properly. The problem is with the input section. Verify that you have the correct input selected. Other than that, the input board is the likely defective section. This is not uncommon and will require service. This is not likely to be a DIY repair if the input board is defective.
Dan
May 29, 2011 | iiyama Prolite E430 17" LCD Monitor
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
Terapin CD-R discs
any digital audio cd-r will work. i found that maxell digital audio cd-r's work the best. you can pick them up a 20 pack for around $15
Aug 26, 2008 | Terapin TX-0002 CD-R Burner
Operators manuel
I have a .pdf of the Owners Manual. If you want a copy, let me know and I can send it to your email address. Kind regards.
Oct 19, 2007 | Terapin TX-0002 CD-R Burner
Terapin TX-0002 CD-R Burner Logo
127 people viewed this question
Top Terapin Computers & Internet Experts
David Payne
David Payne
Are you a Terapin Computer and Internet Expert? Answer questions, earn points and help others
