Question about Canon PIXMA MP530 All-In-One InkJet Printer
More than "one ink catridge installed" problem with new printer
Hi there: i just bought an mp530 and keep getting the error msg: check ink, U071 Y
on the computer screen it says that more than one cartridge of the same color is installed, which isn't true. when i open the cover then yellow cartidge is flashing. if i take it out and replace it the printer will print once, then the same problem reoccurs. any thoughts? many thanks
  • selegant Jan 12, 2008
    great. worked fine thanks.
  • david2155 Mar 18, 2009
    U071, The small black ink cartridge, "Canon CLI Ink Tank" flashes. Printer won't print. I remove and install it about 5-10 times then it will work for a little while. This is one of the original cartridges that came with the printer. I've had this problem for over 8 months.
  • Canon Master
  • 1,113 Answers
Try a new Genuine yellow ink in it, if it fails take to canon dealer for free warranty repair.
Posted on Jan 12, 2008
  • 3 Answers
I had the same problem when using "chip free" cheap cartridges. Use original Canon ink or cartridges sold with a chip. Once I replaced mine with a chipped cartridge, I had no problems at all.
Posted on Mar 30, 2009
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Shows the error msg that the catridgets are installed incorrectl
try to remove the catridges and put it back again. if cannot try to open the printer casing and check out the waste ink placement. sometime there will be an ink that block the catridges placement..
Jun 04, 2009 | HP Deskjet D2360 InkJet Printer
How do i change ink cartridge
open the front panel just lift it u can see the catridges inside that
remove those by just pushing them downwards you can see the instructions of how to remove inside itself in a corner of your printer
try it and buy new catridge and replaceit
or else refil it with the proper advicer
thank you
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error U140 & U071 for Cannon pixma mp800
Thanks for checking back my printer problem. Solved the problem--purchased a new printer.My big problem now is repairs on my Mitsubishi WD 52725. I do not think I will buy a new one of those.I will purchase your help package for help with that. Please advise.
Cosie
Nov 26, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Error Msg 5100
error 5100 pertains to a fault in the catridge ..
Jun 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Check Ink U071 M Magenta Ink is wrong spot, but it isn't. I have checked several times, taken it out, put it back in, replaced ink cartridge, but it still...
your cartridge should must be sitted well at the printer head. check it out and clean it.
did you make a hard-reset, if not yet try it.
  • remove data cable from print
  • switch off your printer
  • remove power card from printer and wait atleast 3-5 min to clear the error message que from printer memory.
  • after 3-5 min, make all connection as well, and turn your printer on.
Thanks
Iqbal
Apr 20, 2008 | Office Equipment & Supplies
Printer thinks the ink cartridge is not installed-- but it is
remove the catridge and re install still you getting the same msg then pls try with new catridge. bye
Sep 30, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
287 people viewed this question
old marine
old marine
