Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Forgot password. want to reset it. Could not access to admin page.
I forgot the password. I reset it by pressing the button at the back. I tried default password, smcadmin. I still could not access to admin page
  • Samskit Jan 12, 2008
    Follow this....
    http://www.dslreports.com/faq/2094
    basically hold the reset button longer... I hold it for 30 sec... it becomes to default password...
    thank me.
  • Anonymous Feb 10, 2008
    same me
Try this:
1) Unplug the power
2) Push and hold the reset button
3) Plug in power
4) Continue to hold the reset switch for 30 seconds
Plug your computer into one of the LAN ports, TCP/IP should be set to get it's settings from DHCP.
Open a DOS window and type IPCONFIG
Note the gateway address - open up a web browser and go to address http://GatewayAddress < Put the number there!
The default pasword for this router is smcadmin < All lower case
Posted on Mar 05, 2008
I forgot my password
you can reset the router to factory default by pressing the Reset button at the back of EW-7206APg for 15 seconds. This will erase all the setting in EW-7206APg and restore the factory default. after that
  1. Open Internet Explorer, at the address bar, type http://192.168.2.1 and press Enter.
  2. It prompts for username and password.
  3. The default username is admin. The password is 1234. Click on Login. You will get the configuration page of the EW-7206APG.
    setup new password
Apr 01, 2013 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
I forgot the security key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 25, 2011 | Linksys WRT120N Router
Forgot user name and password
You need to RESET your router. Press RESET /WPS button for 10 second it is in the back side of router . Then all settings defaults. Then connect it to computer with lan cable.Then you can access it with 192.168.1.1 or 192.168.0.1 type user as "admin" and password as "admin" or blank or "password" or "1234" then you can see configuration page of router.Then reconfigure the router. Let me know if you need further assistance. Thanks for using FixYa.
Jun 19, 2011 | D-Link DIR-615 Wireless Router
I forgot my internet password. how do i get it?
What Password did you forget if you forgot your password for your ISP then you will need to call them if it for the access point then just reset it and you will have to set up the security again Reset button is usually located on back of router/access pointuse a toothpick or similar object to depress button for approximatly 10 seconds.
Good Luck!
Jun 10, 2011 | D-Link DIR-615 Wireless Router
Forgot the password i tried so many times but incorrect allthe times
You will want to try
username: admin
password: admin
username: admin
password: 1234
username: admin
password: password
If these dont work you will want to reset the router back to defaults.
Mar 01, 2011 | NetGear WGR614 Wireless Router
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 08, 2010 | Linksys WRT120N Router
How can i change my linksis wifi password
access the GUI if it still on the default settings otherwise press the reset button at the back
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
Forgot the password
Did you follow the instructions:
from user manual page 31
To hard-reset the D-Link AirPro DWL-5000AP to Factory Default Settings,
please do the following:
• Locate the Reset button on the back of the DWL-5000AP
• Use a paper clip to press the Reset button.
• Hold for about 5 seconds and then release
• After the DWL-5000AP reboots (this may take a few moments) it will be reset to the factory Default settings
by personal experience: it's not easy to reset:
  1. be sure you press the reset button (a click should be heard)
  2. keep pressing longer than 5 seconds
  3. device must be powered.
  4. lights go off and on blinking
  5. you may try several time to be sure you succeed
  6. if successful you connect with Lan cable and log on as admin (no password)
Feb 21, 2009 | D-Link Air Pro DWL 5000AP (DWL-5000AP)...
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
533 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
