Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Wbr-2310 Reset switch is blocked with black epoxy!!!
I get Error 115 during router setup installation. It's telling me to reset router by a paper clip pressed and hold in for 10 secs. I can't do it, b/c switch is covered, molded, blocked with black epoxy. I have purchased this router from Best-Buy in a factory new and sealed box. D-link support guys are useless, they hung up the phone on me three times tonight
thanks
Ronny
  • 35 Answers
Usually only routers custom manufactured for some ISP have their resets blocked. If your router is meant to be universal you can return it for this reason. Are sure th
There are two ways to reset a router like this - with the switch and by entering its admin page. You have to know its password and be able to connect to its admin and reset it from there.
Otherwise you have to uncover the reset somehow if you really need to reset the switch
Posted on Jan 12, 2008
I lost my password and cannot get in into my network , bought a new laptop does not recognize my system
Do a reset.Here is how:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Lost disk, password etc. to my D-Link Router..can I still use it
With the router powered on, place a paper clip into the hole on the back on the unit labeled Reset. Hold the paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults. The factory default username is admin, and there is no password.
May 16, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have lost the password to my d-link router model number WBR-2310 how can i change the password
You will have to do a hard reset on the machine and reprogram it with any settings you had previously. This will wipe all your settings out, so make sure that you dont' have any static or port settings you will need.
Look on the back for a little tiny hole, it will say reset. You will need a paper clip for this part. Hold down the reset button for about 30seconds. You might have to unplug it from the power after this for it to refresh.
Open your browser and got to 192.168.0.1(I beleive this is the ip of this router) and type admin for the user name and leave the password blank.
Here is your router:
http://www.dlink.com/products/?pid=WBR-2310&tab=3
Oct 17, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless signal stops working after some period of time
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Sep 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Lost password
using a paper clip there is a port on the back reset the router back to the defaults the login will be admin there is no password then leave it blank
Feb 08, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Unable to access DLink WBR 2310 Configuration page
At the back of the router is a tiny pinhole. Using a pen try to press it for 15 secs and try to access the page using the 192.168.0.1
Jan 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have forgotten my username and password to my dlink wbr-2310
look for a little tiny reset button, press and hold it with a pen or paper clip for abou 30 secs while the router is on and it will reset your router
Dec 30, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
WBR 2310 Reset Switch
Try this...
--Uninstall the d-link wizard software from your computer...if it actually installed.
--Shut down the computer and router...make sure they're connected together with the ethernet cable
--Turn on the router first.
--Turn on the computer
--Wait about 2 minutes after the computer starts up
--Go to the command prompt and type in the command "ipconfig". This will give you the computers ip address, subnet mask, and default gateway. To get to the command prompt, click on Start -- Run -- and then type "cmd" and click "Ok"
--The default gateway address should be the address of your router...typically it would be 192.168.0.1...but this will tell you if it's something else.
--If the ip address listed after the ipconfig command is blank or begins with 169.... then your computer is probably not talking to the router...the router or network cable may be defective.
--If the default gateway address is something other than 192.168.0.1 ...try that address in Internet Explorer to see if the router will respond properly. If the router responds, you can configure it directly without using the wizard software. Your D-link documentation (on disc?) will guide you through the manual setup procedure...sometimes referred to as the "alternative" procedure.
--Good luck...and I hope this helps!
Jan 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
WBR-2310 router needs resetting 5 times per day
I'm going to bet you have wireless interference...try changing the wireless frequency in the config under channels. Good luck
Sep 09, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
193 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
