Marantz amplifier pm-34
I have an amp. the transfomer has gone and it a split transformer i need silmer transformer as this 1 was like it when i got from ebay but did not state what the problem was. thanks peter
  • 1,512 Answers
The transformer has an internal thermal fuse. If you study the terminations coming out from the internals of the transformer you may notice either a pair of tinned thicker wires or insulated. This may be open circuit. I have often bypassed this internal fuse(they are notoriously common failures) to get a transformer going. You can get a replacement one from a parts supplier if you felt the need. I would just bypass it anyway.:)This may make the amp somewhat "illegal" in the US. We use the MEN (multiple earth neutral) mains power distribution in Australia and the transformer(if melting) would short out to earth and blow the mains primary fuse, the internal thermal is a US requirement.
Posted on Jan 12, 2008
Help please! The book on operation from MARANZ PM-34 is necessary
Posted on Oct 13, 2008
Marantz amplifier PM68 replace fuse
You don't see any glass fuses? There is also a non replaceable fuse in the power transformer.
Apr 06, 2014 | Marantz PM-68 Amplifier
Can i connet my marantz ki17 amp to a power amp
Hi, i don't really understand why you want to connect an amplifier to an amplifer.
Might be that you want to get a louder volume or ?don't know.
I don't think there is any need for you too connect marantz ki17 amp to a power am. Both do the same work, but might have different watts.
So you will need to check what you want to connect with the amplifier first and check the watts that can carry it without interference from the amplifier.
I guess that would do the magic.
Have a nice day.
Feb 18, 2011 | Marantz PM-15S1 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
You need an 8 ohm stereo "L-pad"
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-34 Problem
Hi there
The part that you speak of is called the emitter stabilizer resistor. It is common to the output pair on one channel. You will find that the large "output" transistors mounted to the heat sink either side of this resistor will most probably be faulty.
Best not to run the amp at all whilst in this condition.
To be sure that you have an effective repair, you will need to change both these parts, and also the "driver" transistors that connect to the outputs. They too are in symmetrical positions close to the the output transistors. You should also check that the 3 legged resistor you mentioned is measuring its correct value, and check all other low value resistors in the output stage area to that channel.
If you are not familiar with repairing this sort of equipment, perhaps you can find a repair guy with some experience on audio equipment, then this work should be all he needs to do to repair the amp. I would also ask him to "blanket resolder" the output/bias stages and power regulator stages in the amp as problems with heat stressed cracked/failed soldering and dry joints often cause these amps to blow the output transistors.
BE SURE THAT THE CORRECT PARTS ONLY are used for the repairs. Different transistors could cause future problems with the amp. The parts can be obtained relatively easily from a marantz distributor(we can find one in a country near to you). OR if you can give me the markings to each of the parts you need, I can provide you with an international source to get them from.
The amp is decent HiFi, and worth repair. Happy to provide you any assitance I can, Good Luck
Nov 02, 2008 | Carver PM950 Amplifier
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
358 people viewed this question
