Question about Astar LTV-2701 27 in. HD-Ready LCD Television
It's not turn on and no green light
I opened and look at it . I see burn Power supply board
you know where i can order power supply show me , please
  • Anonymous Feb 17, 2008
    does not turn on
    Problem Solver:
  • 7 Answers
I just finished replacing all 25 or so of the electrolytic capacitors on the power supply board of an LTV 2701 AStar TV. When I got done, the tv came back to life and WORKS GREAT. Every last electrolytic was either leaking onto the board or puffed up or both. The main problem is that Astar designed the case so that no air can circulate over the board and the capacitors bake after a couple of years. If you don't do somethig to let the air circulate, you will be replacing them again in 2 more years. The board is pretty sturdy however and its fairly easy to replace them all with some copper desoldering braid and a 125 watt soldering gun. Just be sure to keep the polarities right on the electrolytics and make sure that they are the 105C variety. Good luck and remember to add some fans and cut some extra holes in the cage.
Posted on Feb 17, 2008
  • Jim Paxton
    Jim Paxton Apr 19, 2008
    Evidently ASTAR lost a $100,000,000.00 Patent infringement suit with Philips and all of their assets were seized. As a result, parts for ASTAR products are no longer available. For all the gory details, check out post 14 at:
    http://forums.cnet.com/5208-7596_102-0.h...
    On the bright side, the capacitors to repair a power supply board cost less than $100.
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Suddenly turned off without warning Sony KDS-50A2000
All you need is to open the back cover of the television and check on for dry soldering at the power stage of the printed circuit board, also check for bulged capacitors, if found replace with same rating of voltages , but if otherwise Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helout, Good luck....
Jul 11, 2010 | Sony KDS-50A2000 50" HDTV
Unable to either use the remote or the buttons on the player to operate the player. The light is red, replaced battery, and still will not function. Isn't the light supposed to change to green?
The power board inside the DVD is burned/ damaged.You need to take it to the service center to replace the power unit.
If you know what to do, you can open the DVD case, then replace the power board.To locate it, simply follow the power cord, power cord attached to the power board.
Replace with same type of boards.
Mar 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Matsui m32lw509 turns on and just flash's blue red and green.
Power supply board it dead,must replaced power supply.Tries Shopjimmy.com,Ebay.com to buy the refurbish power supply board.Know how to solders can tries to replaced capacitors that puff up or bust open might get power back.But because somethings else might also burn have no experience find out what that is, best have the whole board replaced.
Feb 03, 2010 | Televison & Video
Same problem with my D845GVSR
turn off power and reinstall the jumper in normal mode position
Oct 02, 2009 | Intel D845GVSR Motherboard
Inability to turn on plasma screen
You have a power supply fault or one of the drive boards that drive the plasma screen is loading down the power supply. This power supply may be part of the entire main board. Good Luck
Mar 23, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
65 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
