Question about Sharp AL-1642CS Copier
Scanner driver or USB/Parallel
I installed already the scanner driver but it is not found/unavailable when i tried scanning for many times. I checked its properties from control panel (XP) but it is also unavailable. why is that? and how can i use this MFP scanner? i am tired of finding answer, your reply with we my last hope. i badly needed this scanner.
thank you
    Genius:
  • 1,003 Answers
FIRST UNINSTALL THIS DRIVER.
from add remove programs
then download and install printer driver you have or do web search for new printer driver via the web" type in printer driver for
AL 1642CS. you must include operating system version windows xp 98 2000 etc...
Posted on Jan 13, 2008
I hab Bought one USB-to-Parallel connector to connect my Canon Scanner .But I cannot able to scan .It displays Error Code 0*00070800. No scanners detected My Scanner mobel No :Canon N640P ex
I have many years of experince repairing Canon scanners so here is my suggestion.
First off I would go back to USB its faster then a parallel cable for scanning purposes. Second if your computer is a very old one then just get a usb card and install it in to your computer. Also make sure you have the latest drivers for the operating system your running. The drivers are free on Canons website. Just google Canon Canoscan N640P drivers it should take you directly to Canon's website also I would download capture perfect its free also an will function perfectly with your scanner.
When you install the newest drivers make sure your scanner is disconnected from your computer. Once the drivers are installed then attach the USB cable to your computer. You should get a message saying new drivers are being installed then reboot your computer and you should be good to go with whatever you want to scan.
I hope this helps you out.
Mar 31, 2011 | Canon CanoScan N640P Flatbed Scanner
My SCX-4521F Scanner is not working. "System Cannot Found" - Message pop-up on my PC whenever I tried to do scanning. An unknown characters appeared on my Samsung All-in-One Laser Printer every time I do...
1. Reconnect the PC and printer, replace any faulty
cables. If using a parallel cable, check that the parallel
port is properly configured in the BIOS.
2. If printing is OK check that the Scan driver is also
installed
Oct 03, 2010 | Samsung SCX-4216F All-In-One Laser Printer
I want driver for windows 7
It seems that Toshiba's latest driver for this device supports only Windows XP and Vista 32-bit.
Here are the links:
1. Scan/Print Driver, Win 2000/XP v2.30
2. Scan/Print Driver for Vista 32 bit
3. Button Manager for Vista 32 bit
Manufacturers usually drop support for older devices after some time. Specially for printers and scanners the support is even more limited; most of them (if not all of them) offer warranty of one year.
Your best shot is to try the Vista drivers. For printing you shouldn't have problems. When you install the printer Windows have generic drivers for supported (current/older) devices. This driver should work for printing.
For scanning you can try something like VueScan which is compatible with Windows 7. Toshiba devices are not in their list of compatible scanners, but you can never know...
Note that VueScan only works with SCSI, USB and Firewire connections, most wireless Canon and HP scanners (on Windows and Mac OS X only) and doesn't work with parallel-port connections.
This can be solved with a parallel to USB cable converter (be sure to check whether you need male or female parallel to male or female USB converter).
I hope this answers your request.
Nakis
Feb 16, 2010 | Toshiba e-STUDIO 120 Laser Printer
The computer recognizes the hardware, however scanner is not scanning. Have windows XP. How can I tell if the scanner is broken, there are no lights on it?
your scanner is ok.
But there is communication problem from computer to scanner .
For that
Check your usb cxable and usb port of computer working fine.
Try in another usb port.
If you have other port like parallel port then check it.
Check drivers of scanner are instaled proeprly.
Ig already installed then uninstall it and install again.
Also uninstall all usb drivers then restart the computer then it automatic install usb drivers .
you can uninstall usb drivers from computer with device manager.
Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
Jul 31, 2009 | Syscan TravelScan 662
Can't install Fujitsu fi-4120C
I think you have to download the twain toolkit from here:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers/twain/v918149.html
Try that and let me know how you get on..
Chris (ziraffa)
Jan 08, 2009 | Fujitsu fi-4120C Path-Through Scanner
Windows Vista Driver for HP Scanjet 3200C
Help me I need vista 32 bit driver for my hp scanjet 3200c.
Thank you
Oct 24, 2008 | HP ScanJet 3200C Flatbed Scanner
INSTALL AN UMAX ASTRA 1220P TO AN USB PORT ON A LAPTOP USING XP
The 1220P (P = Parallel) does not have a USB port and Windows XP does not support it.
Jun 16, 2008 | Umax Astra 1220P Flatbed Scanner
Software and hookup problems with dell vostro 400
Add a pci parallel card such as this to your vostro. www.tigerdirect.com/applications/category/category_slc.asp?CatId=512
This will enable you to connect your scanner. Tiger direct will give you closeups of the connections on the interface card so you can check you have the right one.
Mar 22, 2008 | HP Scanjet 5200c Flatbed Scanner
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
516 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
