Pump wiring I need to know the wiring order for the pump
    Scholar:
  • 196 Answers
Can you supply a model number and serial number of this unit. Cannot help without this information.
Posted on Jan 12, 2008
I have a 2005 Ford Explorer that has a bad washer fluid pump. I’d like to know what fuse I need to pull in order to put the pump in?
Pump has a plug on connector. Disconnect wires and replace pump. No need to pull fuse. If you don't feel comfortable about disconnecting pump wiring at pump disconnect the vehicle battery.
Dec 30, 2017 | Ford Cars & Trucks
Please i need diagram to 1986 nissam pickup 4wd drive z-24 8 plugs need help w the wiring from distributor to the plugs;need to know order they go back on my email andujarpena@hotmail.com. thanks
Okay you got it here another diagram. If you are misfiring clean out the distributor it has tendency to oil contaminate,or if your burning rich heavy black smoke its the fuel pump not producing enough pressure, Dont confuse this with the MAF sensor your injector is pulse width modulated.3_29_2012_7_20_47_am.jpg
Mar 28, 2012 | 1986 Nissan Pickup 4WD 1986
Installing Spark plug wires
Unless the wires were removed the firing order cannot change as also the length of the wires do not permit that the wires switch over.
All what is needed is to check the spark at each plug , if of low internsity check the ignition system including the HT coil. Also the fuel filter and the fuel pump for the right pressure.
Nov 22, 2011 | 1996 Honda Accord
Need help wiring 6 pin switch on rear of emerson 1081 pool pump.i know how to wire l1,l2 part but not the underneath where the 4 wires goto the 6 pins.can't read nameplate
NOT QUITE SURE ABOUT WHAT U ARE TALKING ABOUT, BUT HERE IS THE ORDER OF THE SWITCH POWER SELECTOR, WHEN IT IS POINTING AT HI THE WIRE UNDER THE POINTER SHOULD BE BROWN AND GOING CLOCKWISE NEXT IS ORANGE ,WHITE BLACK . JAY HE POOL PUMP REPAIR GUY IN LONGWOOD FL
Sep 17, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
I have a heat pump and I can't gret it to cool. It blows hot air when I am calling for cool. I checked the thermostat and i have it set to heat pump. I know it is a thermostat issue, but I don't...
Some newer heat pumps have a circut board that overrides your stat. Those you must program the stat as if it was a conventional. If your system is old here is the typical set-up. You will have this order. G=green wire, W1=white wire, O=orange wire, Y=yellow wire, C=blue wire, R=red wire. W1 is also called aux. G controls the fan, Y controls your compressor, W controls your heat, O controls your reversing valve, R is your 24v power, C is your 24v common. If this hookup does not work you will need to be able to understand your electrical diagram in order to fix the wiring issues and a professional might be required.
Jun 05, 2011 | Heating & Cooling
Fuel pump problem
hi you can do a small test to see if the pump is u/s or the wiring is at fault, locate the 2 wires going to the fuel pump, get a small voltage bulb and 2 wires, find which is the + and which is the - on the pump wires and then tape the wires to the bulb in the order of, out side rim of bulb is - and the bottom of bulb is + then it is just a simple case of turning the key and seeing if the bulb lights up, if it does then its the pump if not then its wiring or fuse fault...you can test pump to but you will need to gain access to a + and - connection, ( i use the rear lights as then you do not need such long wires and just turn lights on to supply the power ) just connect the wire to the + and - going to the pump, and listen for a humming noise if you hear it then pump is ok, if not then pump u/s..phew lol, hope that helps please vote thanks
May 30, 2010 | 1995 Nissan Pathfinder
2000 grand am 3.4 fuel pump wires
IF U HAVE POWER ON GRAY WIRE AND GROUND ON THE BLACK WIRE THEN THE PUMP IS BAD.THE OTHER WIRES ARE FOR THE FUEL GAUGE SENDER
May 13, 2009 | 2000 Pontiac Grand Am GT
I need help on which wires connect to which wires on my sewage pump in order to get power to it? hydromatic sewage pump sp50 I have three wire coming off my hydromatic sewage pump two black and one green....
its 110 v the two blacks are power and green is ground. the two blacks are reversible doesnt matter one goes to white nuetral and other to black hot. ground is ground to metal.
Apr 14, 2009 | Plumbing
Wiring the fuel pump
THIS 1994 Mercury Grand Marquis Fuel Pump Wiring Diagram41873503.gif Mercury Marquis Fuel Pump IS A 94, BUT IT IS THE SAME FOR BOTH YEARS.
Aug 26, 2008 | 1993 Mercury Grand Marquis
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
