Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Defrost not working
I have a 1990 kenmore side by side and the freezer is not defrosting. Removed the coil cover and it was iced over. Checked the defrost element and I have continuity and a small resistance. I turned the defrost timer to a cycle and measured about 12.5 volts at the element plug. Any ideas?
  • sstkelly Oct 25, 2008
    I have the same problem with mine but it is fairly new and that part was just replaced not to long ago so it is hard to think that it would be this agian it is like a $200 dollar part you shouldn't have to fix it alot! what do you think?
  • 410 Answers
Probably a bad def sensor. attached to the top of the coooling coil is a round sensor that senses heat form the def heater and terminates defrost when the coil cleared of ice. the part is model specific and is fairly inexpensive.
Posted on Jan 12, 2008
Frost on coil in back of freezer it is a kenmore side by side
Hi and welcome to FixYa, I am Kelly.
Frost on the back of freezer is a sign of an automatic defrosting problem. On very very rare occasions the evaporator drain gets blocked with ice.
Should you discover a block of ice on the evaporator coils do a manual defrost by unplugging the unit, directing a fan into the freezer compartment for just over 2 hours with the freezer contents removed. (Makes a water mess so be ready) After the manual defrosting session... reload the freezer, plug the unit in ad return it to normal service. After 6 - 8 hours check for ice production. If you have ice production now... you most likely have and automatic defrosting problem where as the defrost cycle is not working correctl;y due to control problem, terminating early or the defrost heater and / or defrost thermostat is not working correctly.
If you want unit specif information.... I will need your COMPLETE model number.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Kenmore Refrigerators
My freezer on my Jennair side by side is working, but the fridge side is not. removed panels and found coils completely covered in ice. defrosted with hair dryer. fan in freezer is working. please...
more than likely the defrost thermostat on the top of the defrost clipped onto the coil is bad,if not it can bethe defrost heater underneath the evap coil thats open and cant heat,or the defrost control board located behind the control panel is bad and not powering the defrost heater and thermostat
Apr 10, 2011 | Jenn-Air JSD2789GES Side by Side...
Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Sep 21, 2009 | Kenmore Refrigerators
Ice under the cover
You can use a hairdryer to speed it up but you need to fix the defrost sytem.
How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 20, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Leaking kenmore side byside Refridgerator . It seems to leakout the freezer door side. Ice builds up at the bottom or floor of the freezer.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model when ice is gone take back cover off find drain hole and clean
Aug 14, 2009 | Refrigerators
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Older Kenmore side by side, freezer warm....again!
"Fuzzy Ice on the back wall" yep, this sounds like a defrost system problem. You say you cleaned this fuzzy ice but, the real ice is behind that wall. I would get it fixed but call several service people and get a price. My guess is that once the defrost system is working then the Ice maker will work. If the freezer is not getting cold enough then the Ice maker won't work.
Now, the drain can cause a problem too but this is an easy fix. Pull out the bottom drawer in the freezer, look in the back under the cooling coils and you should see the drain hole. Keep this area clear of Ice and any thing else. Some tubing with a little air pressure will usually clear any blockage. A little hot water down that drain won't hurt. The water should drain to the a plastic pan under the Ref. Take the front grate off at the bottom of the Ref, look in the pan to make sure it went through.
This should be checked often, once a month or so.
Dec 02, 2008 | Refrigerators
Freezer is freezing up, then freezer and fridge warm up.
hi thanks for your question. you have a no defrost problem. the cheapest part to replace is the defrost termination switch. located in the freezer., its clamped to one of the coils by the fan motor replace this part. see what happens thanks the appliance doc
Oct 30, 2008 | Kenmore 50522 / 50524 Side by Side...
Jenn-air JRSD 226 side by side Fridge
Check to see if there is frost on the rear wall o f the freezer wall. If so, the units cooling coils (behind the frost) may be covered with ice. Defrosting is necessary. The refrigerator may not be defrosting at regular intervals a required. Standing open for a couple of days should defrost it but it will still be necessary to find out why it frosted over. There is a defrost control that automatically melts ice from the cooling coils on a regular basis. Maybe this control is not functioning.
Aug 29, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
