Question about GE 32GT740 32" TV
Help When I press the power button, I hear constant clicking sound like it's trying to come on but never does. Can you help?
    Scholar:
  • 135 Answers
Hi there!
May be a power supply fault, Line stage, loose solder points or regulation( 5V to the CPU) to trigger switch on. If not familiar with electronics, please refer to a repair technician. Regards, JUS004
Posted on Mar 25, 2008
I turn the key and I hear constant clicking and neutral light flashes. when I press the start button it stops clicking and does nothing help me
Sounds like loose battery cables to me. make sure they are clean and tight and battery is fully charged.
Jan 05, 2013 | 2000 Yamaha YZF-R6
Red "TURN OFF" slide bar apears constantly. what can i do
That means, your also constantly pressing on the POWER button.
This bar only appears if you keep pressing on the POWER button for around 5 seconds.
You need to put it somewhere where the POWER button won't be touched / pressed.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Aug 15, 2010 | Apple iPod touch
When i turn on my samsung 62'' inch rear projection tv(model#HLR6167WAX/XAA) it begins to whine like a fan working overtime, I will get a picture for about 5-8 seconds, and then it will cut off and the...
Hi.The ballast may be defective if you hear constant clicking sounds after you've pressed the power button.
If there are no clicking sounds after you press the power button(3-5 clicks every 2-3 seconds), this will confirm optimal ballast performance and, it will also confirm a major issue that concerns the Power distribution board. There are several weak or damaged components on the board that have failed.
The replacement of the power board is recommended in this case.
Jul 08, 2009 | Samsung Televison & Video
TV Does not Turn on
it sounds like the power transformer maybe out on the set.it supplies power to the whole set and it sounds like it only getting partial power.
Jan 17, 2009 | Panasonic PT-52LCX66 Projection Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Str-da777es
I know I'm 18 months late answering your question, but unfortunately I have the same problem. My son kept shutting my on and off same as your daughter. It blew the amp board that obviously powers the amps. Sad news is Sony stopped making the board, so there is no fix. Really bites, I loved that receiver!
Jul 29, 2008 | Sony STR-DA777ES 6.1 Channels Receiver
System sound not working on Dell Inspirion 6000 laptop
There are two sides of the problem. Hardware and software. To check whether the hardware is defective:
Try running the Pre-boot System Assessment (PSA):
1. Shutdown system
2. Press and hold on the "Fn" key.
3. Press the power button to turn the system on while holding on the "Fn" key.
4. Run the PSA until you get to the "colored bars". Then press "N" to say no.
5. Should you hear the beep codes, that means that the sound card is working fine. If you don't hear anything, then you need to replace your motherboard.
Now if your hear beeps that means that there's something wrong with the driver and audio settings. Do the following:
1. Right-click on My Computer then click on Properties
2. Click on Hardware then Device Manager
3. Click on the (+) beside Sound and Audio Devices
4. Right click on Sigmatel then click "Uninstall".
5. Go to support.dell.com
6. Click on Drivers and Downloads
7. Enter the Service Tag of your system (found at the bottom of your laptop)
8. Then download the audio driver. Just save it on your desktop first.
9. Restart the computer.
10. Install the driver.
11. Go to Control Panel -> Sounds and audio
12. Make sure that Sigmatel is the default sound device.
Please rate this solution if this helps.
Thanks,
ArnWuLF
Jun 23, 2008 | Dell Inspiron 6000 Notebook
Why is my tv doing this?
Power supply problem. Usually caused by incorrect or missing feedback voltage...accordianman
Jan 16, 2008 | GE 32GT740 32" TV
Clicking off and on sound
The power supply is in the protect mode. There is probably a short in one of the areas on the circuit boards. It is also very likely that there is a scan failure. The set would have to be properly troubleshooted to determine that exact failure.
Jerry G.
Jan 06, 2008 | GE 32GT740 32" TV
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
