Question about Canon I960 InkJet Photo Printer
AC Adapter My i960 printer AC Adapter is in bad shape. Can I buy one any place around?
  • 32 Answers
3 Suggested Answers
6ya staff
SOURCE:
Rebgagnon
Mike Gagnon
  • 382 Answers
SOURCE: I LOOKIN FOR AC ADAPTER FOR HP F370 PRINTER
Whenever I am need of power cords I use Ebay. Here is one for your system.
http://cgi.ebay.com/AC-Adapter-Fits-HP-DeskJet-DJ460-DJ-460-Printer_W0QQitemZ260290984216QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item260290984216&_trksid=p3286.c0.m14&_trkparms=72%3A1199|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Posted on Jan 30, 2009
Jerry Naidoo
  • 151 Answers
SOURCE: It won't power on..is the ac adapter bad, or something else?
Sorry about that ... my pc just went beserk ... possibly but a sure way to know it to measure its output. Take to any repair shop they would check it for free for you.
Posted on May 12, 2009
My Canon i960 is printing 4x6 prints with what looks like striping very faintly thru the picture. I have done all the maintience and the ink levels are good.
It's a sign that some of the print nozzles are plugged or burned out. A new printhead will give you the good print quality again. QY6-0043-000 around $70.00
Jan 15, 2010 | Canon I960 InkJet Photo Printer
Is my AC Adapter for HP Deskjet F380 out of order?
You can contact PRASHANT 9820930880.
I found this on the net while searching for the adapter. Placed the order just now. Not sure how genuine he is
we have hp all in one adapters model f/310/325/335/340/350/370/378/380/385/388/390/394 @400RS. CONTACT : PRASHANT 9820930880
Jan 05, 2010 | HP DeskJet F380 All-In-One Printer
I want to clean my cannon ip1000 ink pads. How d oI do this ?
Open your printer. Locate Waste Ink Pad inside in your Printer, on the right hand side are quite small.
You can remove the pads & holder with a gentle pull.
Using a tissue, soak as much as ink as possible and clean around the waste ink area.
Be careful & Patient.
Whilst the printer is disconnected from the main power. Press and hold the Power Button and reconnect to AC Power.
Release the Power Button & Press the Power Button Again.
If i am helpful to you, please rate me.
Thank you.
Aug 31, 2009 | Cannon Canon i960 Photo Printer
AC power adapter
17v 2300ma switching power supply.
Mar 30, 2009 | Griffin Technology Amplifi Speaker System...
Jan 30, 2009 | HP Ruggedized DC Car Adapter for HP...
It doesnt turn on!!
You might want to check if it's just a bad power connection first, because a new adapter isn't cheap. They cost about 60 bucks plus shipping from the HP parts department:
http://h20141.www2.hp.com/hpparts/Cart.asp?mscssid=X5RP3M7TBGKQ9H7055FS88LMF259DGG9&NotBulk=&NotFound=&NotOrderable=
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=DESKJET_5100_SERIES&HP_model=&modname=DeskJet+5100+Series&template=main&plist_sval=Power+Module&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Module&catsel=%3F
Before you shell out that kind of dough, I recommend you first eliminate the obvious like a bad surge suppressor or power strip. Sometimes, one of the outlets in a multi-outlet power strip can go bad and cause just one of the devices plugged in to lose power. It actually happened to me once with a brand spanking new surge suppressor I purchased and I had to go back to the store and get it replaced under the warranty. So, be sure to check by plugging your printer into a different outlet.
If nothing's wrong with your power strip and AC power cord, the next thing to check is the power connector that plugs into the back of your printer. It has three contacts on it, which means there are three points of failure. Unplug it and plug it back in. Wiggle the connector a little, mumble "I hate this stupid printer", and then observe the printer's power light.
Still nothing? Well, if you're feeling a little adventurous and have a basic understanding of how electronic circuits work, you can check the AC adapter to see if it's really dead. You do this by testing the DC outputs of the adapter with a multimeter. Don't have a multimeter? You can either borrow one from a geek friend, or buy your own for about twenty bucks at Radio Shack (get a cheapie model - nothing fancy). IMHO, everyone should own a multimeter. They come in handy for checking batteries and bad connections in low voltage wiring. After you learn to use one, you'll wonder how you ever got along without it.
Anyway, getting back to the printer, the AC adapter has a dual DC voltage output with three pins. The center pin is ground and the two on either side are positive voltages (+36 volts and +16 volts). If the AC adapter is good, your multimeter will indicate at or slightly less than these voltages when tested, around +35v and +15v. A good voltage reading tells you that the AC adapter is probably okay. In that case, the problem is inside the printer itself and buying a new adapter would be a waste of money. At this point, it's pretty safe to conclude that the old mule has finally kicked the bucket.
Hope this helps.
Aug 26, 2008 | HP DeskJet 5150 InkJet Printer
I need to buy a new Ac power adapter 0957-2094 for my all in one printer hp psc 1317 can you help
manuf website best choice for compatability, revisit store where bought, possible they have one that will meet specs in their overflow odd box.
Jun 22, 2008 | Office Equipment & Supplies
Car Charger and home charger
my car dvd melted around the edge while it was plugged to recharge in car [email protected]
Feb 04, 2008 | Venturer PVS177W Portable DVD Player
Canon I960 InkJet Photo Printer Logo
Clive
Clive
old marine
old marine
Ekse
