Question about Hitachi 60FX32B 60" Rear Projection Television
Hitachi 60fx32b rear projection
Lost picture but can hear clicking noises. Leds are on and fuses appear good. Any suggestions on things I can check.
  • tommy_2 Jan 13, 2008
    NO the TV never turns on, the clicking noises are just there as though it's trying. The red light on the front stays illuminated
    Problem Solver:
  • 16 Answers
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Posted on Jan 12, 2008
6ya staff
SOURCE:
Hitachi 60fx32b out of focus how can i fix it
If not a convergence issue: each tube (back of set) has a large black lens with a wing nut on side----loosen nut and rotate lens slowly until red is in focus.
Feb 19, 2012 | Hitachi 60FX32B 60" Rear Projection...
My tv no turn on
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty. Simply replace the lamp. If no picture is appearing then the high tension module has failed. The tv must be opened and tested by a pro - too many things can go wrong there for an amateur to dabble in.
Nov 30, 2010 | Hitachi 53UDX10B 53" Rear Projection...
46 in hitachi projection screen -15 years old-won't turn on
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Aug 01, 2008 | Hitachi 43UWX10B 43" Rear Projection...
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Hitachi 43FWX20B
I have a similar pblm. But your first step is to power on with tv's button. Look into the back through holes and look for 4 green and 1 red LEDs lit. If not there are 3 fuses on the power supply board.Fuses can be easily changed.
next step call service.
Apr 16, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 60fx32b is dead with no lights on front panel
The two other fuses look like resisters. My suggestion would be to check them first and if bad use a temp of the same rating to see if it was just a power surge.
Apr 14, 2008 | Hitachi 60FX32B 60" Rear Projection...
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
No picture
Replace vertical output IC and check soldered in pico fuses...T.
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60FX32B picture
Replace vertical output IC with first quality part,check caps
in vertical power supply......If you don't have access to parts,
then solder pins of IC,should hold for awhile.
If you need further assistance, let me know.....T.
Oct 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Televison & Video Logo
257 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
