Question about Samsung SPP4231 42 in. EDTV-Ready Plasma Television
Samsung spp4231 plasma analog video
My samsung analog video, both composite and coax does not work, tried multiple input sources. Can I just replace a video card?
  • 29 Answers
No video card in the tv but the main board is probably bad
Posted on Mar 15, 2008
How to set up vhs taping
Most VCRs need to be connected in a daisy chain or a splitter from your input source. (You may need a tuner with some VCRs these days; either a digital to analog converter for a VCR with an NTSC tuner or a different tuner source.)
If you have analog cable or a cable box with coax out and a VCR with an NTSC tuner, use the daisy chain method. Connect the incoming cable or the coax out from the cable box to the VCR's coax input. Then connect the VCR coax out to the TVs coax input.
For a VCR without a tuner, you'll probably find a RCA composite video line in option on the VCR. Connect your cable box or converter box composite output to the VCR composite in. For an OTA source, you'll need a splitter to send the signal to both the TV and the converter box.
Most TVs do not have a video output option.
I hope this helps.
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Having trouble hooking up vcr
I've never seen a VCR use anything other than Composite, S-video or RF analog outputs. That's because VHS uses the NTSC or PAL analog video standards. (In the US, it is NTSC; in Europe PAL is the old standard.)
To use the Composite output, get a triple RCA cable (red, white and yellow connectors). Connect one end of the cable to Video Out (yellow), Audio Out right (red) and Audio Out (white) on the VCR. The other end of the cable goes to the corresponding Composite Video In jack and the adjacent Audio In jacks on the TV. If you are using S-video, (both units must have S-video jacks), the S-video cable replaces the Composite section of the triple cable, so you only need an audio patch cable (two RCA plugs on each end). Be sure to use the audio input corresponding to the S-video input. Note: S-video is generally better quality than composite, although HD digital is still superior.
If you wish to record from the TV, the TV must have a composite video or S-video output. This is not very common. If you wish to record programs from an RF source (cable or antenna), see the next paragraph.
In the days before digital, a typical connection scheme was to run the cable or antenna RF source to the ANT IN coax connector on the VCR, then run a short coax cable from ANT OUT to ANT IN on the back of the TV. This may not work with a digital source. Pre-HD VCR tuners would not be HD compatible, and may even filter out the digital signal in bypass mode (VCR off). You would need an HD to analog converter box at the VCR input to retain this setup. I have no information on your TV's support for NTSC video through the tuner (especially since you did not mention the model : /).
Jun 21, 2011 | LG Televison & Video
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Componet input do not work. Error messages searching for signal,.. no input signal. It is not the source or the cables. Can wiggle the componet inputs on tv and get flash of pix or intermittant. Samsung...
the wiggling of the cables and actually getting a response usually means there is a lose connection/cold solder joint. Narrow the possible connections down and resolder the few solder points or take it to a repair shop.
Jul 21, 2010 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Samsung LN-R329D has fuzzy video. Menus look fine.
thats a good assumption. try multiple sources and see if its just the one source. if its fuzzy, maybe youre using coax cable?? and the cable is bad or has poor signal. try tightening all the connections and making sure the cables are ok, let me know if this doesn't help.
Jun 06, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Nope, nope and nope... It's likely the DMD board and unless you have some SMT (surface mount technology) equipment just laying around you're not repairing that board too easily... You could however remove it and send it in to PTS for rebuild at about half the cost of a new replacement..
Dec 08, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
No video from rgb inputs
usually this is a bad connection on the system board, cable, etc.  If it's not under warranty, I would check the cable first, and try multiple video sources before opening the unit.  Worst case scenario is replacing the system board where the connections reside.
Oct 19, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Samsung SPP4231 42 in. EDTV-Ready Plasma Television Logo
148 people viewed this question
Jerry Greenberg
Jerry Greenberg
