Question about Hitachi 60FX32B 60" Rear Projection Television
No picture When the problem fisrt started there was about 6 inches of vertical and now there is no picture at all. There is the click, click, click for a few seconds but then that's it. Fuses appear good, leds are on
    Genius:
  • 1,694 Answers
Replace vertical output IC and check soldered in pico fuses...T.
Posted on Mar 02, 2008
6ya staff
SOURCE:
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
My Toshiba mw24h63 has a vertical foldover about 6 inches high at the top of the screen. What is the cause and can it be easily repaired?
caps in vertical circuit. 100uf or 220uf . the ic is in the middle back long ic with about 10 to 12 pins on a heat sink. caps are bad and utube has pictures.
Nov 04, 2010 | Toshiba MW24H63 TV
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Dec 08, 2008 | RCA F35673MB 35" TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Toshiba 35 inch picture tube problem
HELOO THE SET IS HAVINGA VERTICAL FAILURE ,REPLACE THE CONDENSERS AND ANY BURN PARST IN VERTICAL SECTION.AND AT LAST REPLACE VERTICAL IC IT WILL BE OKKK.
May 21, 2008 | Televison & Video
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Picture is thin.
Looks like you have a problem with the Vertical Output stage of the TV. Unless you know something of solid state Electronics servicing , there is nothing you can do.
May 13, 2007 | Hitachi 32UX01S TV
Televison & Video Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
