Question about Video Game Consoles & Games
When I first turn on my Rayman2 game, it displays the following message: "Corrupted or damaged controller pak detected" It plays the game ok but it won't save it when I turn it off. It doesn't do this with any other game but I got another Rayman2 game and it did the same thing.
  • batgirl Jan 12, 2008
    Why would it work fine with other games and not Rayman 2?
    Scholar:
  • 128 Answers
You have to get a new controller pak.
Posted on Jan 12, 2008
N64 powers up but no video or sound
Important Note:
We highly recommend you review the following precautions before you set up and operate your Nintendo system:
Important Safety Warnings & Precautions
Hardware Precautions / Maintenance
Game Pak Precautions / Maintenance
Precautions Concerning TV Screen Damage (Image Retention)
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo A/V cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting the each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo A/V cable into the "multi-out" connector on the back of the Control Deck.
After system is connected to the TV:
Insert Game Pak fully into the Control Deck.
Plug the Controller(s) into the front of the system using the left most port for Player 1.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It's often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play!
If after following these directions completely you are not able to view the game, try our Troubleshooting Tips.
Jan 04, 2013 | Nintendo 64 Console
Pokemon stadium said that i need pak but i have one
Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Jan 02, 2013 | Nintendo 64 Console
I found my old N64 console, I only have a rf cable with it but when everything is plugged in i cannot find the channel. My TV is quite old. People say it's 3/4 but i try these and it didn't...
Nintendo 64 AV to TV Hookup
Important Note:
Installation Steps:
Dec 26, 2012 | Nintendo 64 Console
My gameboy advance sp resets for no reason then sometimes also if I touch the game pack or the screen part it will reset then too.
Important Note:
A few older Game Boy games may not function properly on the Game Boy Advance systems, causing display or sound problems. Also, a few multiplayer games may not work properly.
Note: It may be difficult to play Kirby's Tilt 'n' Tumble due to the motion sensor in the game, and the different orientation of the Game Pak in the Game Boy Advance SP.
Because the Game Pak is situated upside down in the Game Boy Advance SP, players would need to tilt the game in the opposite direction of where they want Kirby to roll.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
General Game Pak Troubleshooting Steps:
Check the list of specific game issues to see if there are any known problems for the game you are playing.
Make sure you are using only licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Remove and firmly re-insert the Game Pak into the system. The Game Pak label should be facing away from the machine. Be sure the Game Pak is fully inserted. You will know it is fully inserted when you hear it click in place.
Turn the system on and test the game again.
If it still doesn't work, remove all accessories to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
What to do if Troubleshooting doesn't help
Game Boy Advance Games
We recommend contacting the manufacturer of the game. We can only offer assistance on titles made by Nintendo. For titles made by another company, you will need to contact that company to see if game pak replacement options are available. Please use our Licensee Directory to find the company's contact information. If you are not sure who made the game, you can use the Game List section on this website to look up the game. Who made the game is provided under "Publisher" information. If the game is made by Nintendo, please click here to find out what options are available for repair or replacement of your product.
All Other Game Boy Games
Due to the age of these games, repairs are unavailable. We recommend purchasing a replacement from a retailer or online auction site that carries older products. For more information on locating older products, click here.
 Game Pak Troubleshooting - All Game Boy Systems
Important Note:
Dec 20, 2012 | Nintendo Game Boy Advance SP GBA Red...
My Nintendo 64 Controller Pak is not working.
Well it might be an internal issue with the console then. Like the console might be confussed that would occur if you do not use offical Nintendo stuff more problems occur with unlicsened products.
Nov 21, 2011 | Nintendo 64 Console
My rfu cable just has an av and control out cable no rva cables how do i hook it up?
Important Note:
Installation Steps:
Sep 08, 2011 | Nintendo 64 Console
I have a saved game of Pokemon Crystal on Playr.org but when I go to load it, a screen comes up saying "This Game Pak is only designed for use on the Gameboy Color"
Hello, I've had the same problem and been able to go around it somehow. Before I load my save, there is a second or two of in-game screen, then It shows "nintendo" and then "the game pak is only designed for gameboy color". During those seconds, QUICKLY click Save Game and do it multiple times. Some save files will still be with the odd message, while other will run perfectly. I suggest you save your game multiple times and very often, then you can test If then are running correctly, and delete the corrupted ones, or load an old one. Good Luck
Apr 21, 2011 | Nintendo Pokemon Crystal
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
Controller Pak Abnormality???
Sorry evilpacman, but you're wrong.
The N64 Controller Pak does indeed have SRAM as you state, but SRAM _does_ require a battery to retain its contents. The battery in question is a standard CR2032 or "coin-cell". The only gotcha is that it is a PCB mount variety, with the legs already attached to the battery casing. I'm currently looking for a replacement myself... farnell may have them but I need to check the footprint...
Jul 13, 2008 | Nintendo 64 Console
Video Game Consoles & Games Logo
48 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
