Question about Magellan Roadmate 760 GPS Receiver
760 in limbo
Wish I saw this web site before..after the software install and entry of my authorization code I got 'waiting' superimpsed over the progress screen and 'loading' on the GPS screen. After a long while an error box on the pc stated communication with the GPS was gone and to unplug the USB reset the GPS and re plug the USB. hello?, how do you reset the GPS when it continues to have 'loading' on the screen even after unplugging and re plugging into power. Tech support did not speak english very well suggested I go into my computers config sys and start checking and unchecking lines...can you believe this! Now I think my 760 is like all of yours..finished..anf the software upgrade cost $100 with shipping for nothing. Now it is Friday PM and they are closed till Monday when the fun begins...I have a day job so not sure how I am going to fit in hours of tech support nonsense.
  • 1 more comment
  • Anonymous Feb 01, 2008
    Mine does the same thing and says there is a corrupt file and to run chkdsk utility. What a mess
  • Anonymous Mar 19, 2008
    Unfortunately I've experienced a similar problem while trying to download a map "upgrade" (turned out the upgrade was the 2006 maps version, probably the same as was loaded on the machine when I bought it in August 2006). After powering on the 760, connecting it to the computer usb and starting the dvd the map upgrade program started and appeared to be progressing normally (the download process takes several hours). The 760 intermittently showed "Loading". As the process was nearing an end the pc program suddenly abended and the application disappeared from the screen. The 760 showed "Loading". At this point I left the configuration in place overnight. The following moring nothing had changed. No application on the pc side, "Loading" on the 760 screen. At this point I disconnected the usb connection, thinking I would reboot the 760 and try again. The 760 screen immediately went dark and I have been unable to power the unit on.
    I initially sent an email to customer service, which went unanswered. I then called customer service and while that service is off shore and I had to explain several times what happened I did receive what sounds like a definitive resolution. The 760 has been discontinued, Magellan offers no service for it, the 760's memory has been "damaged", and I was advised to take advantage of a trade-in offer and upgrade to a new machine. I did investigate the offerings on magellangps.com and was not able to find any trade-in offerings.
    So. I would suggest no one try to upgrade the map set on the 760. I don't see any way to power the unit back on to try to restore the content. I do not plan to replace this with any other Magellan product.
  • cty_boy2008 May 20, 2008
    need to update my magellan roadmate 700 to the news street, cuase i live on new st, but it comes up as oold one
    thnks
    any program i can download 2 do that?
    thsnk
In early Feb/08 I went through the same frustrations as all the other RM 760 owners when attempting to download the map up-grade. After endless attempts to talk to someone who could give me a solultion(and not get bounced around the world) I gave up until I returned home in April and re-started the whole process once again. I was requested to send my defective unit for servicing with their promise that they would inform me of the results and solutions.
I rec'd nothing. Today, I finally contacted their service department...went through all the ID process again. I was told that my 760 is un-repairable and that it would be replaced by the Maestro4250 at no cost. I should receive the replacement unit within the next 4-7 days. Lets hope this is the end of this journey and beware of up-grade offers!!!!!!
Posted on May 07, 2008
I too persisted with the folks in India, and I was told that their servers were down 4 times that I called and they could not give me an RMA #. I tried the email route several times and finally I was fed up and filed a complaint with the BBB. I received an email from Magellan asking me to contact the Support group again, I refused! Then I received an email with a UPS label to send the unit in for repair. I sent the unit in, and 10 days later, I received a box from Magellan with a replacement unit and a note stating that my RM760 had failed...duh...., anyhow I was sent a replacement, but the "new" one is a RM700. I figured that because the unit is functionally equivalent to the RM760 with updates, I am not going to push the issue. I am so glad that this nightmare is over....as long as nothing happens to the replacement unit...... :-|
Posted on Apr 04, 2008
GHDS:
Well it is April and tought I should update...of you persist with Magellan support in India for about 3 hours or so ypu will gey a return number and address...if after several weeks after you send the 760 to the return address and nothing happens call again with a tracking # for your shipment etc and persist and they will agree to send a new 4210..which since it has arrived is a good GPS except it does give street names a s you approch.. other than that I like it better than the 760..good luck
Posted on Apr 03, 2008
I'm in the process of filing a class action lawsuit with Magellan. I've had the similiar issue and so have many others I've spoken with. If you would like to be part of this please email me at [email protected] subject class action 760
thanks,
V
6ya staff
SOURCE:
Why won't it turn on?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 02, 2015 | Dynex Televison & Video
Why wont my lg tv turn off manually or with remote? The sound won't respond either.
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Try a reset to this set, before contact the authorized service centre. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 15, 2014 | LG Televison & Video
I have a sharp aquos 32L400m and I saw a K appearing on the top, by pressing channel - & vol- I went into service mode and reset the destination to MIDDLE EAST - my channels appeared again. Th
Sep 12, 2014 | Sharp Lc-32l400m 32" Wxga Aquos Tv Lcd
Problems with resetting Sanyo dp32640 without remote control
Without its remote control, you can't make a system reset [Factory reset] to it. You have to enter its service mode, to do this.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 26, 2014 | Televison & Video
What is my authorization code??? pls tell me...
Hello.
If you have lost the product key to your software or device, and you have previously registered the software or device, or have a proof of purchase for the software or device, contact the manufacturer and they will provide you with a new product key.
FixYa and it's experts do NOT provide product keys, serial numbers, illegal software, authorization numbers or codes, warez, hacks or cracks under any circumstances. Any expert that does so will be barred from answering questions. Those asking are subject to their membership being deleted and be barred from the site. Additional misuse of FixYa may subject you to Federal charges. Please note that IP addresses accessing this web site are logged.
Thank you for using FixYa.
Sep 05, 2009 | Adobe Photoshop CS2 for PC
Authorization code
Aug 22, 2009 | Adobe Photoshop CS for PC
Need activation code
Hello.
Aug 13, 2009 | Computers & Internet
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
System software missing nuvi 760
To the best of my knowledge, I will try lodging into the garmin site, and try to download the software and re-install it again. It work for me, and now the new 2010B maps update its available. It takes awhile to download & install but pays off.
Hope it will help you solve the problem.
JADF
Apr 11, 2009 | Garmin Nuvi 760 Car GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
134 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
