Question about Toshiba 65HX81 65" Rear Projection Television
Picture went off then Red light blinks all the time
My Toshiba 65H81 (2001) picture went off and red power led blinks constantly. Unplug / replug will keep light off, but if trying to turn on, just blinks with no picture.
What can this be? And will it be easy to fix?
I keep staring at a blank screen :-(
Thanks for any help
  • 7 more comments
  • Normy31 Mar 03, 2008
    Sold TV, but helpful
  • Normy31 Mar 04, 2008
    Thanks again, I sold it as is, thanks for the help
  • davey2008 Mar 10, 2008
    ** picture, red blinking light, stops when unplugged and replugged, then starts again when trying to turn on tv.
  • Damn Skippy Mar 25, 2008
    I am looking to buy this model and it has the red light blinking and no picture. I bought the service manual and have heard talk about replacing the PD0074 board. I see these are going for $287.00+
    Does the step by step allow you to trouble shoot the board and just replace parts on it rather than replace the wole thing?
    Could you please email me the step by step too? Thanks.
    BTW If anyone wants a peek at the Service Manual let me know.
  • maria39 Sep 17, 2008
    I am having this problem.. I have sound, but no picture.   A red light at the on off switch just blinks.  can you share the info with me please?   thanks!
  • tstarkey Oct 22, 2008
    I have the same issue had a tech come look at it he said it needed a upconverter and the part was like 400 bucks, anyone have a fix for this problem?
  • mustngangl Dec 27, 2008
    The red power light just keeps blinking and the television will not turn on, just a blank screen.
  • JerryMcPhers Feb 11, 2009
    I have the same problem as others have dexcribed. What can be done to fix this? I was just watching a program and it went out?
    My tv for the past several weeks was blury for the first few moments
    when you turn on the TV - it would go away after a couple minutes - but
    it was taking longer and longer.
    Any help would be great.
  • dkooz May 11, 2010
    I would like step by step. Thanks......dkooz
  • 1,694 Answers
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
Posted on Feb 01, 2008
  • Vista Electronics Mar 03, 2008
    I gave you procedure on Feb 23.............................T.
I’m having a problem with my Toshiba 42HL196. Once or twice the red LED was flashing and I held the power button in for a bit and it started working again. Today I was having cable installed and after a...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 13, 2017 | Toshiba 42HL196 42 in. LCD HDTV
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
May 03, 2010 | Toshiba TZ43V61 43" Rear Projection...
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 60HX70 distorted picture, blinking red light
You could have a Power Supply Regulator Problem. Many times these sets will not hold Horizontal sync when there is excessive High Voltage or a problem with the High Voltage Regulation. This is not a problem you want to deal with yourself. I would recommend a Toshiba Repair Facility to come out and diagnose it.
Hope this helps,
Jul 22, 2009 | Toshiba 61HX70 61" Rear Projection...
Power went low all things went dim since then are tv's are all red picture and sound fine but all red
You need to first: Unplug TV and let it sit 20 minutes.
Then replug it... Then you may have to set the red, blue and green guns if this is a projection TV>
Jan 03, 2009 | Toshiba 43H70 43" Rear Projection...
Blinking red light
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 65HX81 65" Rear Projection Television Logo
496 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
