Question about Promise Ultra133 TX2 ATA Controller
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I am trying to install a 2 port ATA-133 IDE adapter card to a desktop computer that already has an existing bootdrive & DVD. Unfortunately, this computer only has 1 PCI slots on the mother board so if I want to add 2 more devices I have to use an IDE card. I have tried several ways.
1) both hard drives from master - boot (master) 2nd (slave)
2 dvd drives off of IDE adaptet (one master, one slave)
2) Keep existing set up off mother board - hard drive (master), DVD (slave)
try to set up another harddrive and DVD (master, slave) of ide adapter
I have change my jumpers to slave, cable select, master...etc
I can't seem to get them all four to work. It appears it is reading my IDE card - scanning.....but will not boot. Only when I have two - whether harddrive/dvd or 2 harddrives, etc.
Is there something I am doing wrong? Could this 133 IDE adapter not be compatible with my "new" computer? I am using the "primary" slot on it and only one cable.
desparate for help!
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Posted on May 02, 2008
I want to download all info from my desktop and motherboard into mylaptop
Hi Eva!
If your desktop is crashed, then you will need to verify if its internal hard drive is still working, and then conect it using an USB/SATA/IDE adapter to your Laptop. This is one:
If the problem with your desktop is with its hard drive, then... you need to take your computer to its manufacturer technnical service center.
Sep 27, 2012 | Sony VAIO PCV-W600G PC Desktop
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided;
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
Ultra ata 133 ide controller........i installed this on a brand new gigabyte MB with windows 7..........Device manager knows its there but with a problem. I cannot locate drivers for this device...
if u cant locate the drivers name, try using unix base(linux) live cd's, like knoppix for example, they usally detect all the drivers u have in minutes and even gives u all the names and serial numbers, then u can download them.
Apr 30, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
IDE drive install in SATA computer
can you remove a disc drive and use the hard drive in the original ide slot?
you pci adapter may not work with your motherboard, not all cards are compatible with all boards.
Feb 27, 2009 | Maxtor Hard Drive
Hello, I have a PCI Ultra Ata/133 Dual IDE card. I have two Ide devices hooked to it. Everytime I hook it up in the system My regular Motherboard IDE says can't be read, reboot. I am trying to get not Raid...
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Jan 12, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Promise Ultra133 TX2 ATA Controller Logo
259 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
