Question about Sony Playstation 3 (PS3) Console
Dns error 80710102
I had changed my dns ip before when it happend but i cant find a way to fix it again i need another dns address
  • Anonymous Feb 09, 2009
    i have a dns error 80710102 and using a belkin extender g universal
    Novelist:
  • 109 Answers
Hey peterk18,
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type www.google.com in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
Greetings,
DarkNeogen
Posted on Jan 23, 2008
I can not log in to my ps3 even though it says that my connection is 100% strong. The error code that it gives me is 80710102
Error code 80710102 implies your router is having issues (specifically, there's an IP conflict).
The simplest fix would be to just restart your router.
If that doesn't do the job, you could use a DNS alternative to the one you're currently using (IP addresses are assigned by DNS, thus why we would change the DNS provider) such as OpenDNS. To do that you would manually set up your internet connection. A detailed guide on how to do that can be found here.
Basically what you would do is navigate to XMB > Settings > Network Settings > Internet Connection Settings. Then you would select custom. For all of the options you would select "Automatic" or "Auto-detect", except the DNS setting. For that you would manually enter the OpenDNS alternative, which are these:
208.67.222.222
208.67.220.220
Hope that helps!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
Tried connecting my ps3 with the wi fi . It obtains ip address successful but fails to connect to the internet . It says dns error 80710102.
Go to the PS3 Network Setup, choose "Manual".
Leave the option for DHCP under "automatic", and under DNS servers, manually add:
208.67.222.222 or/and
208.67.220.220
These are the IP addresses for the Open DNS project and now your PS3 will be able to resolve internet addresses.
Mar 08, 2011 | Computers & Internet
My ps3 has a nds error 80710102 then is a ip addres time out can u av tried wifi and direkt help thanks
The main issue is your DNS not working. The fix is simple. When configuring your PS3 network (regardless of wired or wireless), use the manual option. If you use DHCP, leave address resolution at automatic BUT CHANGE THE DNS SERVER ENTRY TO MANUAL.
Replace your DNS server to the ones below which are from opendns.
The DNS addresses are:
208.67.222.222 or/and 208.67.220.220
Once replaced, you should have no problem logging in. You are having an IP address timeout because you don't have a working DNS to resolve ip addresses.
Hope this helps,
Omeil
Jan 31, 2011 | Sony Playstation 3 (PS3) Console
Hello, can you help, on my ps3 it keeps coming up with error 80710102 and will not connect to the internet or find the wireless box
This is a common dns error with playstation.
try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
PS3 DNS error (80710102)
see i hav the same prob try putting this in
primary dns 208.67.222.222
secondary dns 208.67.220.220
ip address 192.168.1.45
if that dont work people say u should unplug your router 4 a couple of minutes then plug it back in
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Can't connect to the internet wireless, I get a DNS error (80710102)
Try disabling the "WEP" key on you router. I've read the solutions from other contributers and tech's and this solution seemed to really work.
May 31, 2009 | Sony Playstation 3 (PS3) Console
.trouble with playstation 3 getting on line through router...
It looks like there are a lot of DNS servers that do not work correctly with the PS3. Below I will list a few DNS servers that do seem to work and you will need to manually configure the DNS settings for your PS3 to any of these addresses.
208.67.222.222
208.67.220.220
129.250.35.250
129.250.35.251
4.2.2.1
4.2.2.5
Nov 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Dns error # 80710102 ip address ok but internet connection fails
Contact your network admin or Your ISP (Internet Service Provider)
-Rel
May 28, 2008 | Sony PlayStation Portable (PSP) Slim...
Internet connection failed but IP address obtained.
Hi, i had the same problem but it was fixed by simply re directing my ISP's DNS settings away from Sony's. manually change your DNS settings to the ones below and it should work fine !
  • 208.67.222.222
  • 208.67.220.220
  • Nov 23, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    237 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
