Help with TV
I have double on the screen and an oval at the top and bottom of screen, TV is 9 years old, hardly used and I purchased new in 1998. Sears Tech is charging $ 88.00 to come diagnose the problem....HELP !
  • romac1 Jan 13, 2008
    The Model number of the 52 " RCA TV is : P52810LV, Manufactured May 1998
    Please see photo.
    Thanks again, feel free to reply to personal e-mail address
    romac1@sbcglobal.net, was having trouble getting the uploaded picture down to a size to fit in this post , but can e-mail you a picture of the problem...Thanks !
  • 8,617 Answers
What model number is your set? Can you upload a pic of what your screen is doing? It sounds like you Convergence amps are faulty which is a common problem with all projections as they run hot. Its a fairly cheap fix under 20.00 if you can solder you should be able to handle it easy enough.
Posted on Jan 12, 2008
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
I have a 9 year old mitsubishi projection tv
Could be a problem in the high voltage section or a bad signal board. Let the TV tech do it.
Good luck
N Sabre
Nov 08, 2009 | Mitsubishi VS-60607 TV
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Purchase of the RCA F27252GY 27 INCH TV
My set of the same model shows a build date of 1998. New 27 inch basic sets sell for 100+/- on sale at varius stores. I'ld say the value is no more than $25. for a 9/10 year old working table model TV
Nov 16, 2007 | RCA F27252GY 27" TV
Year 2000 mitsubishi 64 inch tv
Have convergence IC's changed in your 60" TV. I only use ORIGINAL IC's, not generics or knock offs. Most companies that fix have no idea what the difference is.....
Oct 31, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
Oct 18, 2007 | Sony KP-53V85 53" Rear Projection...
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Sony LCD Problem...
I have a problem with my sony bravia KLV-46V200A.
Screen is black out and power light is flashing red six times per cycle.
What should I do. I bought it about a year.
Thanks for your solution.
Sep 19, 2007 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
