Question about Brother IntelliFax-2820 Laser Fax
KEEPS FLASHING DOCUMENT JAM!
ALTHOUGH THERE ARE NO PAPER JAM IT KEEPS FLASHING,
HAVE DISCONNECTED OVER NIGHT AND STILL DOCUMENT JAM FLASHING. PRESS STOPBUTTON SOUNDS LIKE ITS STARTING BUT
WILL GO BACK TO FLASHING DOCUMENT JAM.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,363 Answers
Check these locations carefully
1- where you feed the documents there is a sensor lever to detect a document, look carefully and push on it gently it should go back in place ( spring action)
2-before the drum there should be one
3- there is one in the fuser, YOU MUST look for the sensor usually after a jam a piece of paper is torn off and left on the sensor ( hopefully it was not broken off)
Posted on Jan 14, 2008
6ya staff
SOURCE:
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
Deskjet 930c; after a paper jam, the fault (middle)lamp keeps blinking. When I press it, a sheet of paper is drawn halfway through and a second press of the button completes the paper passing through. But...
there is a piece of paper left from paper jam inside the printer. open the printer in rear side portion and remove the paper inside. don't open in front of the printer it can damaged some mechanical parts of your printer.
Mar 22, 2010 | Office Equipment & Supplies
The power and paper light keeps flashing
This could mean that a 2-sided document was sent to the printer and the printer is waiting for the page(s) to be reinserted to print on side 2. Check your documentation or the HP support page http://h10025.www1.hp.com/ewfrf/wc/product?product=75045&lc=en&cc=us&dlc=en&lang=en&cc=us
for more information.
The power light blinking indicates the printer is preparing to print a document. The resume light indicates 1) needs paper, 2) a paper jam anywhere in the printer, or 3) the ready to print side 2 of the document.
I hope this helps.
Dec 06, 2009 | HP DeskJet 3820 InkJet Printer
STILL paper jam with no paper
first of all disconnect the power cable from the bak fo the computer
press and hold the power button for 20-30 seconds with the power cable disconnected
reconnect the power cable back to the printer
turn onn the printer
check for papers inside and at the rear access door of the printer
still if does not work follow the document from the url below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00860153&cc=us&lc=en&dlc=en&product=3418705
if still nothing works
call hp if the printer is in warrantty they will surely replace it for you ....................... thank you
Oct 17, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Brother HL-5240 printer problem
This usually means a print job is stuck in the queue that was set to "manual feed" or to a different paper size, such as legal. Add paper to the front manual feed and press "Go". If this is the problem, the stuck document will begin printing from the manual tray.
To clear the problem without printing from the manual feed, cancel all jobs on the printer, delete any jobs out of the Windows print queue and restart the computer.
Dec 04, 2008 | Brother HL-5240 Laser Printer
Paper jam
Here is a troubleshooting document from HP, It is in depth and should help you solve your PJ error.:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&lang=&rule=35051&product=306892&docname=buu03110
Good Luck,
Joe
Please remember to rate Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 08, 2008 | HP PSC 1350 All-In-One Thermal Printer
Brother IntelliFax-2820 Laser Fax Logo
352 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
