Question about ASUS A7V8X Motherboard
ASUS A7V8X hangs @ splash screen
Computer hangs at splash screen. The computer repair shop said after replacing the battery and diagnosing the system the MB is dead. My choices are one, pay the shop $250 to replace the MB on an old outdated Slot A system, two, throw away the machine and buy a Dell "reconditioned" machine ($500) so my 14 year old can continue to chat his life away, or three, buy a used A7V8X MB online ($50) and replace the MB myself on the kitchen table never having replaced a MB before (only cards, memory, etc).
Words to the wise? How do you replace a MB? Can I pull-off the chip? Differences between A7V8X-LA, A7V8X-X ( I have a plain A7V8X)
  • 2 more comments
  • sbianco1 Jan 12, 2008
    OS: Windows XP Professional. Thank You for your reply
  • sbianco1 Jan 13, 2008
    Thank You for your assistance. I'm going to being it to another shop. My 14 year downloads everything on that machine.
  • Suave4455 Apr 03, 2008
    I have formated the hard drive, and it will boot to the C: drive. I boot from the XP cdrom and it goes thru the inspection, then blue screen with iqrl_not_equal
    or hangs. i have changed to New Kingston Memory 2X1GB, no new hardware installed, nothing in pci slots. i boot to dos and after awhile machine locks up.
    First time experience with this situation, you cannot Flash the BIOS (That i found, that is the correct flash) flashing the BIOS can be Dangerous. HP is no
    help. Cannot find any help from ASUS either?????????
  • brian c
    brian c May 11, 2010
    Can you specify what OS it is?
  • 2,351 Answers
Just because an installation may hang does not mean the board is dead. If possible I would connect the hard drive into another PC and check for a virus. While in another pc you can remove important data from the drive & copy to a CD/DVD. Than download the drives Mfg's drive software setup program that will run in Dos mode from a diskett. Reformat the drive and install a fresh copy of windows. You might find that is the only problem. Xp does not always install correctly. There may be a software or hard ware making windows hang.
Posted on Jan 13, 2008
Asus x5dab
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 21, 2013 | ASUS Computers & Internet
I have a asus eee pc 900hd it is stuck on a stsrtup screen and i cant get it to da anything
Hi Amanda.
When it is like that you usually need to reinstall the operative system (Windows or Linux). Try first turning off the netbook and removing the internal battery for one minute. I don't think that will work.
You can also try accessing the RAM modules in the internal slot and checking they are well in place. Do this with battery and power off. Do not touch the chip contacts. electrostatic discharge from your fingers can damage them.
If that does not work, then the system must be reinstalled. The unit does not have internal DVD player. The system is reinstalled using an external DVD player and an operative system install disk or using an USB disk where the OS install files have been previously copied. The system setup is commonly done at any local computer shop for a small fee.
Sep 19, 2011 | ASUS Eee PC 900HD Netbook
My Motherboard: ASUS A7V8X turns on then turns right off
check all leads from motherboard to hard drive including electrical and all of your cd/dvd drives make sure the connections are good and not faulty and there is no dust built up on them
make sure your computers ram modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
or to find out what the problem is
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
if you need more help with this post a reply
hope this helps you
Aug 29, 2011 | ASUS A7V8X Motherboard
Computer shutsdown completely when i insert my 80gb seagate barracuda 7200 HDD
What operating system are you using some can only recognize up to 10GB
and is the 80GB fitted correctly
stripe on cable to No1 pin on M/board socket and toward the 4 pin power socket on hard drive
Is could need a new cmos battery. Look on your motherboard for a battery the size of a quarter. There ease to replace but be careful that you don't bend the metal clip.
Jul 23, 2008 | ASUS A7V8X Motherboard
Hi, click on this link to load all the drivers for the Asus A7V8X-MX SE motherboard.
You might want to add this to you're favorites.
Jul 12, 2008 | ASUS A7V8X-MX SE Motherboard
Wow, just buy a gaming computer. The burn-in, compatible components, warranty, all those things are sooo nice. Take a lot of burden off the whole system.
AlienWare has really good stuff.
Dec 01, 2007 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
ASUS A7V8X Motherboard Logo
571 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
