Question about Samsung HL-P6163W 61" TV
White spot on screen
My TV has been great until today when I noticed a small white spot on my screen. How can I fix this?
  • Stivo1975 Jan 12, 2008
    Are you sure this will work on a DLP flat screen?
  • Stivo1975 Jan 14, 2008
    I appreciate all your help but I think I'm whipping a dead horse here. The TV is out of warranty. It has the "dead pixel" on all inputs. DVD, Cable, Video games, etc. Someone said get a new screen? How much is that? Maybe I'll just watch the TV with the little white dot on it. Oh well.
    Genius:
  • 1,601 Answers
  • 1,113 Answers
Sounds like you are describing stuck/dead pixel.
There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel
Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
Posted on Jan 12, 2008
  • 3 more comments
  • Soulvisitor
    Soulvisitor Jan 12, 2008
    retraction not a LCD screen sorry my mistake,
  • Soulvisitor
    Does the spot occur with all different inputs? Could you tell its size and does it move, please ensure it is not a replaction from a external source on screen.
    Thanks
    S.
  • Soulvisitor
    replaction is or should be wriiten as Refection.
  • Soulvisitor
    The only possibility I can see for a projection tv to have a white spot on its screen are
    Light entering back of screen, and being repflected on to screen
    It could be due to electrical interference, from internal or nearby sources
    Outside light source ie window/lamp reflection being seen on screen surface.
  • Soulvisitor
    DLP technology explained...
    DLP (Digital Light Processing) technology utilizes a small digital micromirror device (DMD) to tilt micromirrors less than the size of a human hair in width toward or away from a white lamp inside the DLP television. This process creates a light or dark pixel on the face of the projection screen, depending on how much light is reflected by the mirror. Each mirror can turn on or off several thousands of times per second, so this technology can reproduce 1024 shades of gray. There are four main components in the system: the DMD chip, the color wheel, the light source, and the optics. Light from the lamp passes through a color wheel filter and into the DMD chip, which will switch its mirrors on or off in relation to the color reflecting off them, producing an image.
    Whether spread across a flat-panel screen or placed in the heart of a projector, all LCDs are pretty much the same. A matrix of thin-film transistors (TFTs) supplies voltage to liquid-crystal-filled cells sandwiched between two sheets of glass. When hit with an electrical charge, the crystals untwist to an exact degree to filter white light generated by a lamp behind the screen (for flat-panel TVs) or one shining through a small LCD chip (for projection TVs). LCD monitors reproduce colors through a process of subtraction: They block out particular color wavelengths from the spectrum of white light until they're left with just the right color. And, it's the intensity of light permitted to pass through this liquid-crystal matrix that enables LCD televisions to display images chock-full of colors—or gradations of them.
I have a 46'' RCA LCD TV With Dark Spot covering about 30% of screen
it is ultra hard to fix broken LCD sectors unless you have a micro-shop intrusion tool. The fastest and most direct way to fix this is to purchase another LCD screen, which will cost about half if not more than the original purchase.
Apr 20, 2014 | RCA 46 46LA45RQ LCD TV
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Samsung flat Screen white spots and more everyday
Ur light projection engine is the cause.Must replaced this,well solved ur problems.I think Samsung recall this problems,to fix it for free awhile back.Call Samsung customers sevice ask.
Apr 08, 2010 | Samsung DLP HL-P5663W 56" TV
White spot..
Yes, if you order NEW screen starting price 500.00 .
Aug 09, 2009 | LG RU-52SZ51D 52" Rear Projection...
White sparkly spots on screen
Dynex is a brand from BB which is very very poor for parts. It does have a problem, I would return it for a refund and look for a name brand. If I can be of any other help in your search for another one, please let me know.
Jun 07, 2009 | Dynex DX-LCD37 TV
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Samsung HL-P6163W 61" TV Logo
286 people viewed this question
Jerry Greenberg
Jerry Greenberg
