Question about Sharp Actius AL27 Notebook
Keyboard randomly stops working
I have a Sharp AL27 that recently just got over a huge crash. It had a power shot and the hard drive had to be replaced but anyway, the keyboard after this time has started giving me problems. It seems to randomly stop working when the motherboard loses power say when unplugged and the battery dies which is in about 10 mins. But if left plugged in the thing is fine. I have to pull out the ribbon cable and plug it back in while the laptop is on and then it works. Although i have noticed when its working the icons on the desktop will start flashing as if a button is stuck down somewhere and the mouse flashes as if the computer is busy and when the computer starts up it asks me how i want to start windows and only does that when the laptop keyboard works. Other then that the computer works great but does this sound like a motherboard problem, and hopefully not, or more of a keyboard problem? If keyboard do you know where i could find one to buy? Thank you
  • 1 more comment
  • Ravensfan Jan 12, 2008
    Eh, Kinda, im using the oem keyboard and the computer cant be used on battery power because battery dies to quick. I meant more like the computer keyboard seems to work until the motherboard loses power say via the battery dying. Like for example if i were to unplug the computer and let it just sit and the battery dies and when i go to turn it back on thats when it dies. But if i leave it plugged in it seems to stay working for the most part. Ive had to open the computer up twice to reset the keyboard. If the keyboard is bad do you or anyone else know where i could find a pc al27 keyboard to replace it with if thats what it seems is the problem?
  • Ravensfan Jan 13, 2008
    Okay, Thanks, ill see if that works. Out of curiosity though where on fleabay where would i look for it? Ive tried using ebay but can only find certain parts for it but nothing along the lines of a keyboard.
    Okay. Well thank you for your help, if a keyboard dont come up then i can always try and see if getting a new battery would help too. Thanks TampaNative.
  • 778 Answers
If this only occurs on battery power and your battery only holds a 10 minute charge? And your keyboard is external (PS2, or USB) it draws power from that battery (even the OEM keyboard does) and is probably glitching on you for lack of power. That's of course if I have understood you correctly?
Good luck.
Posted on Jan 12, 2008
  • 1 more comment
  • Frank  Fernandez
    Frank Fernandez Jan 13, 2008
    Again, since the Keyboard only fails on battery failure, I would look at a battery, but you should be able to pick up that keyboard on fleabay for under 20 bucks.
  • Frank  Fernandez
    You should just be able to search your manufacturers name and the model number of your unit, and that should bring up parts and possibly broken units (broken displays, etc...) that you could salvage a keyboard from.
    You just have to be persistent, I just searched your model number and came up with several parts including displays, a bezel, memory, and power adapters. I'm sure that a keyboard or a busted laptop with a good keyboard will come up. The only question is when?
  • Frank  Fernandez
    You are most welcome Ravensfan.
I have a sharp avtius al27 laptop. Do all hard drives for laptops fit mine? my hard drive is ATA and new one I ordered is SATA,2817,1046951,00.asp Read that. You can't just jam a SATA drive into your machine if your old one was ATA
Mar 10, 2011 | Sharp PC-AL27 Notebook
How to upgrade memory. I need module definition for 1Gig so I can purchase it.
You need a 512MB PC2700 DDR 333MHz SO-DIMM for a laptop (200-pin). The manufacturer I think doesn't specifically support anything over 512MB. But the RAM is standard and I doubt there is any need to buy it directly from Sharp. The laptop only has one upgradable bay so you may not be able to upgrade past 1.25 GB.
One of the memory covers is not removable, if I remember correctly, that is the one under the keyboard. So the one you update is a panel on the bottom.
Mar 11, 2010 | Sharp Actius AL27 Notebook
System inoperative. Keyboard lights are on, power indicator lights are lit, cant tell if hard drive is spinning computer makes buzzing type noise upon start up
There are Problem with your hard drive it has been pls check with another hard drive if its working fine then pls calll vendor for the same.
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
Removing files from a dead lap top
If the computer is dead the only way to recover the files would be to remove the hdd & install it as a secondary hdd in another system in order to copy the files. After you are sure all your data is copied you could then either reformatt & keep as a storage drive in other system or remove. You'll need the proper cables as most laptop hdd's just slide into a built in port on the laptop's mb. Hope this helps.
Mar 30, 2009 | Sharp Actius AL27 Notebook
Laptop Sharp PC-AL27 Heatsink Cooling Fan\none found
If it's an older laptop, sometimes you can find a parted out one on e-bay?
Mar 03, 2009 | Computers & Internet
USB Ports on AL27 only work with printer and external hard drive.
I fixed the problem by going to "Device Manager," then to the "Universal Bus". Under "Universal Bus" are a list of the individual USB ports. You have to delete each one individually. When you delete each one, a window opens up which gives you various headers; select "drivers" and hit "uninstall". When you hit "uninstall", windows will ask if you want to proceed. Select "Yes". You'll then get a "warning" that the computer may not work correctly if do this procedure. You want to proceed with the deletion of each Universal Bus port. Once you've removed the Universal Bus ports, then reboot windows. Windows will detect the individual Bus ports and find new drivers for them. Once the drivers are installed (automatically by Windows), the USB ports will be operational.
Nov 15, 2008 | Sharp Actius AL27 Notebook
Sharp pc al27
swap the memory sticks around,this usually works for me.
good luck
Mar 19, 2008 | Computers & Internet
Laptop troubleshooting
bad chips on mobo then replace it motherboard
Jan 21, 2008 | Sharp Actius AL27 Notebook
Sharp Actius AL27 pixel problems
From what you described, it seems as though your LCD panel is going bad or the inverter board is bad. Does it change colors if you were to reposition (tilt) the LCD back and forth in either direction?
Nov 30, 2007 | Sharp Actius AL27 Notebook
Sharp PC-AL27
There was a post I read on a notebook forum site that deals with a BIOS problem with the Sharp Actius PCAL27 from a guy named fixyourlaptop AT yahoo DOT com. He stated that he was a Sharp tech, and that the main problem with the AL27 is not the battery, but the BIOS.
There is apparently an issue with these BIOS that causes the power usage of the battery to show incorrectly. I purchased my laptop over three years ago, and just recently updated the BIOS sent me by this fellow, and my laptop battery discharges properly. It still only has about an hour of life but this is the first time it ever worked right.
You can email him for the fix at the above address. Just put in the subject line SHARP LAPTOP AL27 BIOS FIX. He is legit and the fix worked like a charm.
If you want to read his post just do a search for the above (properly formatted) email address on google.
Nov 01, 2007 | Sharp Actius AL27 Notebook
Sharp Actius AL27 Notebook Logo
378 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
