Acer Aspire 5610-4648 Notebook Logo
Posted on Nov 21, 2009
I have no backup or restore systems. I need to restore to factory settings. Please help.
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jan 26, 2009
SOURCE: restore factory settings for aspire 5570
Try re install windows and then go to http://support.acer-euro.com/drivers/notebook/as_5570.html and you can find all the drivers there.
Anonymous
  • 32281 Answers
  • Posted on Feb 27, 2009
SOURCE: disk drive problem
Windows auomatically makes system restore files. These files allow you to restore your system to a previous date should there be a problem with your computer as a result on an installation of a "faulty" program. You can also create a Restore Point (date) if you wish, prior to installing a program.
To create a Restore Point or restore your computer to a particular date, click on Start - All Programs - Accessories - System Tools - System Restore, and follow the prompts.
How. Do I take acer touch screen PCs to factory settings
Hi. Most computers have a hidden partition on the hard drive that contains all the factory default settings and system software that originally came with the PC, including the operating system (like Windows 7/8,etc.). There is a simple method to restore your computer to factory default settings using this restore partition. Please be sure to backup any data or files that you want to save on a USB flash drive or backup media first.
I presume that your computer is an Acer Aspire One model touch-screen PC. For this model of computer, in Windows, go to "Start," then "All Programs," then "Acer Empowering Technology."
Then, you want to click on "Acer eRecovery Management."Then, click on "Restore," then lastly, "Restore System To Factory Default." Your computer will then reboot/restart, and launch the Recovery Utility.
When prompted, click "Yes," then "Yes" again to restore/revert your Acer computer to its original factory default state. Please do note that if you deleted the recovery partition from your hard drive by formatting it, you won't be able to use this recovery option. If that is the case, you should be able to use the original system DVD's that came with your computer to restore it to its original factory defaults.
I do hope that I have helped you. Please feel free to ask further questions if you still have need. Thank you.
2answers
How can i restore factory settings without password
You can only restore the BIOS settings by selecting F2 on reboot. You need the password to restore operating system settings. Geek squad can break password.
5helpful
4answers
Hello how do i restore my acer aspire 5332 laptop to factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at
http://www.vtechsquad.com/acer-support/
I Want To Rest My Computer To The Factory Settings, I Have ASUS Essentio Desktop Model #CM1630-06, Please Help Me. Cleon
1. if you have windows operating system then go to your start button 2. search for backup 3. go to backup and restore 4. choose the restore factory settings or if it says recover system settings then choose that one
2answers
I have an acer aspire 5310 laptop and want to restore to factory settings can you help me please
Hi Friend, Please try the following steps:
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
NOTE: Please make sure to backup all the data from the system before resetting it to factory settings
Please let me know if these steps were of any help
My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
This could be your HDD, failed. Work through, the troubleshooting procedures.
Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
Windows not loading
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
1helpful
2answers
I want to reset it
If you face any issue with your Acer Notebook, feel free to get expert technical assistance at
Reboot my Acer Notebook
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
