Question about Palm Treo 755p Smartphone
755p issues when the phone resets, all the custom ringtones that were recorded and assigned to each contact, reset to default.  The ringtones were recorded on the phone as the name of the caller.  I have go through every contact and change the default to the specific sound.. other issue, is when traveling, I set the roam preference on home only so I dont roam. but when I hit okay, it reverts back to allow roaming
  • 23 Answers
For the first part, make sure you sync the phone and are you using after you pick the ringers.
Second Part, I had this problem make sure you press ok i was using other keys like back assuming it would not, what service do you have because most current plans do not charge roaming unless you use more than 50% of your minutes while roaming.
Masalama
Sheeraz Khan
Posted on Feb 12, 2008
6ya staff
SOURCE:
How to change call ringtone on nokia e63
Hi Violin,
I have this steps for you for work around setting up call ringtone. Hope it helps.
--- there should be no prob to set a custom tone if you go to the tone and select options you should get an option to select from a list from the menu otherwise go to profile and select edit then when you come to ringtone select options and you will get options you should be able to select a tone from the gallery
---I discovered something about this problem. It appears that if you have the same phone number assigned to two (or more) contacts the ringtone plays the default ringtone. Once I deleted one of the contacts with the same number, it played the correct custom ringtone. What is strange is that both contacts had the same ringtone. BTW, the reason I had done this was to simplify the voice command to make a call to this contact.
Apr 25, 2014 | Nokia E63 Cell Phone
Different ring tones
To assign individual ring tones:
1) you must go to the phone book, highlight the wanted contact, click on options and then edit.
2) scroll down until you see the section "ringtone" and click on it.
3) Then choose audio, then ringtones. click on the ringtone you want, you must listen to it first, and then click on "select".
4) if you want a ringtone to be something you've recorded, click on "my voice" rather than "ringtones"
May 25, 2009 | Pantech C610 Cell Phone
My problem is i cannot use my download songs to my ringtone or my alert tone?i have it on my audios in my phone.. when im going to put it on my ringtone there's nothing on my audios? my phone is lg rumor...
ur wrong about using a video file. I tried that and gives u no option to do that. on way is to use the voice recorder and assign from there under custom ringtones.
Mar 13, 2009 | LG RUMOR Cellular Phone
Assigning downloaded ringtones Razr V3a
Before you can assign a ringtone to a contact, you must first go to "settings" and then to "ring styles". Click on "Detail" and go down to "Ringer IDs". Make sure it says "On". After that, you should be able to assign a ringtone to a contact by editing the contact details. (Custom ringtones are at the bottom of the list instead of at the top.) Hope that helps.
May 30, 2008 | Motorola Mobility RAZR V3
Assigning ringtones to a profile
Do you often change your sim card. If you change sim card it may happen.
May 22, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Ringtone problem
Hey,
U can only assign any mp3 ringtones only if it is placed in Phone memory. U need to make phone memory as default storage device. U can do it by going to options when in multimedia->pics/sounds/video clips.
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN([email protected]/[email protected])
May 17, 2008 | Motorola Mobility RAZR V3
Tranferring ringtones from SDcard to palm treo 755p
You can use a FREE program for the palm OS called minitones, you can yahoo or google it, which will allow you to convert mp3s you have on your SD card or on the phone to a ringtone that you can assign to a contact. minitones.prc
Mar 23, 2008 | Palm Treo 755p Smartphone
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Phone will not ring
Thanks, The orange dot on my phone was showing as well. That fixed the problem.
Jan 21, 2008 | Apple iPhone Smartphone
Phone button assigning error
I think you are going to have to hard reset that to get it back to factory default. Sorry.
Nov 26, 2007 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
