Question about SVP DC-12D Digital Camera
Batteries and Memory Cards
What do you recommend for rechargable batteries and for memory card for this camera. And where can I purchase them?
Thank you.
    Problem Solver:
  • 35 Answers
Hi There Tensnow Thank You For Your Post
Best Solution For Battery Wise NickelCadium Rechargeables Most Are Accessable With Pc. Bascially Hookin To Pc's Usb And It Charges While You Work Or Play
And Best Solution For Memory Is Either A 512Mb Or 1Gb The Reason Easy Storage And Won't Slow The Proccess Down
And Best And Cheap Solution Is www.Ebay.com.au
Hope This Helps And Don't Forget To Rate Me :)
Thank you
FixYa
Posted on Jan 12, 2008
6ya staff
SOURCE:
Won't read sd cards
If this happens with the second time, great chance it has nothing to do with the card(s). Your camera should be capable of handling all SD cards. So SD, SDHC and SDXC cards.
But perhaps something came in the memory card holder of your camera. Just a little piece of paper or dust? Please check if all the contacts in the camera are clean and shiny.
Then there is a warning in the manual, about the batteries you can use.
A list of batteries, if used can damage the memory card, because these batteries can't deliver enough power to make writing on a memory card reliable. The warning is on page 14 of the (English) manual. Only one type of battery can be used. Only Ni-MH rechargeable batteries should be used. Although the manual says Alkaline should go to, I have to advice against that. because they too can give less power, in certain situations (like in cold environments)
The memory cards that gave these error messages, should be checked in an external memory card reader on a computer. And when they are connected, please give them a format there (FAT32)
If you had the wrong batteries in the camera, after putting in fully charged NI-MH batteries, you could try to format the cards in the camera too.
Feb 03, 2014 | Panasonic Lumix DMC-LZ20
My camera won't turn on, even though the batteries are fully charged. HELP!!!
the batteries might be to old. rechargable batteries go bad after a lot of recharges. you can get new batteries at wallmart and other stores!! Good Luck!! :)
Apr 03, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
I have problems when turning the camera on and preparing to take a picture - the viewfinder is totally blacked out. I have a brand new digital camera battery installed.
try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty) Please also try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair. Connect the camera with the computer. Turn the camera on. Click onto the link and follow the instructions. http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=6607/6614&product=EKN029416 If successful please give me the feedback as a rating or recommendation. Thank You
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
My camera worked very recently, as I took pictures on a camping trip. However, a few days later after getting back, I've found that it refuses to turn on. If I turn it to either Video or Photo, the light...
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare CX6200 Digital Camera
Camera won't turn on
4. Upload new firmware:
Turn the camera on.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11888/11893&product=EKN034495
Jan 01, 2010 | Kodak Easyshare C813 Digital Camera
Lens opens but the screen does not turn on and then the lens will not retract back into the camera. Help me quick!
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty) 4. Please also try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair. Connect the camera with the computer. Turn the camera on. Click onto the link and follow the instructions. http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=10511/10542&product=EKN032941 If successful please give me the feedback as a rating or recommendation. Thank You
Dec 30, 2009 | Kodak EasyShare V1003 Digital Camera
I'm going through batteries like crazy. Is there a recharger anyone can recommend for the EASYSHARE Z1485 (crv3 3v)
Here are the steps:
NB: You are using the correct battery pack.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 20, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Camera purchased 6 weeks ago and it does not turn on now. batteries read barely into good area on battery charger. thought regular AAs would work, but they don't. HELP!!
Try new Alkyline batteries again ... (not heavy duty ones).
Make sure the batteries are inserted in the correct polarity... I'm sure it's the batteries.
Sep 08, 2009 | Kodak EasyShare C913 Digital Camera
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
    • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
    • If the is not resolved , continue with the next step.
    Step two: Check for damage or corrosion on the batteries
    1. Open the Battery/Memory card door on the camera.
    2. Remove the batteries.
    3. If the batteries are damaged or show corrosion, replace the batteries.
    Step three: Recharge the batteries
    1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
    2. Try turning the camera on after the batteries are fully charged or have been replaced.
    Step four: Ensure the batteries are installed correctly
    1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
    2. Try turning the camera on.
    Step five: Turn on the camera without the memory card
    2. Remove the batteries and optional memory card from the camera.
    3. Wait 15 seconds.
    4. Re-insert the batteries into the camera, but not the memory card.
    5. Try turning the camera on.
      • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
      WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
Whenever I put batteries in the camera I can take a few pics then it says battery dead. Is it the memory card or batteries. Any ideas?
That is a common problem only solved by purchasing rechargeable batteries and a battery recharger. The flash on digital cameras use massive amounts of battery storage. If you do a lot then get about 8 batteries and a matching recharger.
Jun 26, 2009 | Olympus D-555 Zoom Digital Camera
SVP DC-12D Digital Camera Logo
Top SVP Cameras Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a SVP Camera Expert? Answer questions, earn points and help others
