Question about Toshiba 65H81 65" Rear Projection Television
Toshiba 65H81 blank screen and red blinking light....help
Hi, the 65H81 stopped working today and the red power light blinks! Is it bulbs or worse?
Help!!
thanks
Normy
  • Anonymous Jan 19, 2008
    I have the same problem
  • mikebpdx Jan 19, 2008
    I'm having the same problem. This looks like a common occurance on this model. Does anybody have a solution?
    Problem Solver:
  • 5 Answers
I had the red blinking light problem on a toshiba 55s rear projection. It happens once in a while 6 mos ago, but gradually shutsdown after 45 sec or so lately. search the net and found www.casias.com repair log. typical hunch on convergence ic or power supply problem. Decided to replace convergence ic bought at Suburban Electronic Wholesalers ebay store ($15 for 2pcs of STK392-110 ICs). Removed the board at the back 9 screws and wirings (make sure to mark it). removed a electronic board (soldered) that hinders access to the ICs and removed/replaced ICs. You can go to casias.com for actualy pix. And voila!! my TV is now back to normal... I would say if nothing is physically wrong with your motherboard (fuses, etc.) most of the time it is the convergence IC. It doesnt cost much.. so start from there..
Posted on Mar 17, 2008
    Problem Solver:
  • 6 Answers
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Posted on Mar 10, 2008
6ya staff
SOURCE:
Red light blinking
google to see several posts on projection tv red light blinking from several different manufactures (sony; toshiba; samsung; philips; you name it) and several models.
http://www.avsforum.com/forum/63-rear-projection-units/975795-toshiba-65h81-went-black-blinking-red-light-help.html
Apr 16, 2016 | Televison & Video
RED POWER LIGHT BLINKS
Red power light blinks and tv will not turn on it is a 65h81 Toshiba HD
Jun 19, 2009 | Toshiba 65H81 65" Rear Projection...
Power led blinking
possible.. convergence ic can cause this problem if they become shorted
Apr 16, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 blinking power light
Hello
I have the same thing going on with mine. What it is the SLR main Reg. is bad. The only way you can fix it is you can't put just one part in it you have to replace one of the boards. When you open the back panel up you will see three boards in a roll the one that needs replacing is the power board you have to get the model number. My Tv is a 65 HD model 65h81 the board on mine has a part number of PD 7400 yours will have something like that. Well let me know how it's goes my E-Mail is [email protected]
Feb 14, 2008 | Toshiba 65H81 65" Rear Projection...
Picture went off then Red light blinks all the time
Not an easy fix....requires chassis pull, careful soldering and
replacement of parts and fuses.....would you like step-by-step?
........................T.
Jan 12, 2008 | Toshiba 65HX81 65" Rear Projection...
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 65H81 65" Rear Projection Television Logo
486 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
